Thread: About to add borates. Question first.
    Jul 2010
    Philadelphia
    134
    I have successfully lowered my TA from 130 to now between 70-80. I will get it squarely to 70 in the next couple of days and want to add borates. My CYA is high enough now (about 70) that I am running the SWG less so the constant pH rises are likely to be slower, esp with the TA down more.
    From what I have learned about borates, they are a buffer and therefore will increase the amount of acid needed to drop pH relative to water without borate added to it. I also know that people have varying opinions about their addition but I want to try them out.
    Anything other effects I should be cognizant of *ie making other chemistry more difficult to control) since getting them in is easy but removing them isn't? Trying to measure twice and cut once.
    Thanks
    Evan
    ph 7.0 (reducing TA still)
    TA 70-80
    CH 220
    CYA 70
    FC 10
    19000 gal in ground, pebble tec. Sta-rite system 3 DE filter, Aquarite SWG, raypak 406A heater
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: About to add borates. Question first.
    Quote Originally Posted by shacke
    ...Anything other effects I should be cognizant of *ie making other chemistry more difficult to control)...
    Nope...sounds like you are on the right track. I have had them in all season and its a piece of cake.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Mar 2009
    Huntsville, AL
    156
    From what I've read, you will be using the same amount of acid to maintain your pH in a given band -- with borates you add larger quantities, but less frequently, to stay in your pH range.
    I added borates last year (using 20 Mule Team borax and MA) and the pH of my pool now tends to sit right at 7.6 for a long time (4 or 5 weeks) between MA additions. Before adding borates I was adding acid every week or so to keep the pH between 7.4 and 7.8. But I have a vinyl pool with a SWG - not plaster with a SWG - so your pool may act differently.
    Hope that helps,
    Gordon
    27K gal, IG vinyl, 1.5 HP pump, 24" sand filter, Goldline Aqua Plus SWG
    Jan 2008
    Northeast Florida
    161
    Before borates, I tried to keep my pool between 7.2 and 7.4 and it would creep up to 7.8. With borates, bringing it down to 7.2 is a waste of acid because it won't stay there. Mine settles in about 7.5 and stays put, which is higher than I was accustomed to, but since it doesn't creep up to 7.8, there is no need to get it any lower. If you like to keep a low ph, borates might not be for you.
    The first time I borated my pool, I used Borax and acid. I recently replaced the liner and this time I used boric acid from Duda Diesel. I highly recommend the boric acid. It was quick and easy and I didn't have to mess with acid. The $20 difference in total cost was worth it to me.
    33' above ground pool, 52" deep, about 27500 g
    sand filter w/zeobrite
    Jul 2010
    Philadelphia
    134
    I have been keeping a level of 30 for a while now and I am putting myself in the camp of those who don't see the benefit. My pH rises are just as fast and as large a swing as before. Every time I turn around it is at 7.8-8.0 after lowering it to 7.4
    I was thinking maybe it is my turbo clean system in the pool bottom - there is always agitation/aeration on the surface. Maybe that and the SWG are too much for the borate buffer. I hesitate raising the borate to 50 in case my troubles get worse. I am going to plenty of acid still - plenty.
