Thread: stabilizing my pool
    Jul 2010
    Mount Carmel, Illinois
    35
    stabilizing my pool
    I don't understand what to do on the stabilizing.
    Here are my pool readings
    FC 2-4
    pH 7.3
    TA 100
    CH 250
    CYA 30-50
    Pool Size - 6000 gallons
    Filter - Cartridge
    Above Ground Pool
    22,553
    Re: stabilizing my pool
    Welcome to TFP.
    If by stabilizing you're talking about the chemical (cyanuric acid) and not structural, then please post where you're located and how you go those test results. 30 to 50 ppm CYA is what's recommended so I'm not seeing a problem. Your FC needs t come up a bit but other than that it looks good.
