Results 1 to 7 of 7
Thread: AG pool wall woes
    AG pool wall woes
    Hey folks
    Long time lurker here. I have a 4 year old AG Salt water pool. 27' Vogue Oceania. I lost all my water due to a tear in the liner which to be honest I don't know how that even happened. So after contacting the pool place that installed the pool 4 years ago and ordering a new liner and salt and liner guard, the day finally came when they could install it. They were very quick in stating they can't due to the wall not being in the track.
    I asked the installers what would cause this and they said a shoddy initial installation. What other things could cause a wall to not be in the track? I have 1 year left on the installation warranty and the inspector person is coming out later this week. I am just assuming they will blame me somehow for this.
    I will admit that the pool deck did rest slightly on the top rail of the pool, not where the wall is out of the track but not so heavy that the top rail could not be moved around slightly under the rail. I have since removed that deck board. The liner installers said I should not have it resting above the top rail but assured me that could not cause the wall to leave the track.
    I just want this dealt with since my family and I have been without a pool all year.
    The installers said the track was buried under some sod and looked like the wall had not been in the track at all.
    I have included some pics.
    Any insight would be appreciated.
    27' Above ground salt water pool. Hayward Ultramax pump, Hayward Pro ST10T2 filter, Zodiac LM Chlorinator.
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Re: AG pool wall woes
    If the pool is empty you should either get the orig installer out to fix it or just do it yourself. Its not hard to do with the pool empty.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    The pool is empty and the installation is still under warranty. I don't want to muck with it and void the remaining warranty. Hopefully it is a quick easy fix and I can get swimming again.
    Aug 2009
    Hattiesburg, MS
    84
    Not a hard fix and this could actually be the cause of your torn liner. The pool wall can pinch the liner causing it to snag and tear in some places. Sorry about your trouble, but really the sand needs to be cleared from the track and the wall will slip right back in if the ground has not dented the wall in any way. I had a couple of dents on mine and we just straightened them with a pair of pliers. Looks like you may have had a bit of a sand blow out or wash out. Common problem and easy to fix.
    18x33 Delair Sunsation GS AGP Oval 4 shallow-6 deep mostly buried
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    That is correct. Unless your INSTALL has a warranty that prevents you from touching it, the pool itself will not have a warranty that prevents the owner from fixing the issue or all of us DIY installers would voided ours the day we unpacked it from the shipping crate.
    When I replaced my liner this spring my wall popped out of track. Simply sweep the sand and soil away and finish with a shop vac or leaf blower to get it all out of the track. Lift and pop back in. Re-shape your cove and smooth the bottom. Ready for the liner. It really is very easy. I did the entire liner removal and replacement job myself. So anyone can
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Was your liner tear in the same spot?
    Hey all
    The hole in the liner was not in the same spot and there was never any water being washed out at that spot. It all came out right near the hole. The hole ss about 8 feet or so to the left of that and on the bottom of the pool. I am glad to hear it is a simple fix so that shouldn't be a big deal.
