Results 1 to 13 of 13
Thread: Raising CH
    Raising CH
    I'm thinking of adding calcium chloride to raise CH a bit. Where is the best place to buy it and will it make my water taste salty?
    Thanks!
    22,553
    Re: Raising CH
    Welcome to TFP.
    When asking a question especially about a particular chemical please post a set of test results an how you got them. And since you're asking where, you should also include your location.
    This is because we don't like giving blind advice and you may not even need more CH in your water. Also If I lived in Canada and you lived in Mexico telling you where I buy pool stuff will do you no good.
    Re: Raising CH
    Good point, I thought about that later. I have a 24k gallon white plaster pool. I live in coastal southern california, and have a couple of water features that aerate the water while the pump is running. My pH rises pretty fast, so I need to add MA regularly.
    I have a Taylor k-2006 test kit. Here are my latest results:
    FC: 4.5
    CC: 0
    pH: 7.6
    TA: 70
    CH: 250
    CYA: 35
    I was thinking about getting the CH up to 300 and leaving my TA where it is at.
    Thanks!
    Guest
    Re: Raising CH
    I would leave your hardness level at 250ppm. It will rise with evaporation. What are you using for a sanitizer.
    22,553
    Re: Raising CH
    That's what I'm talking about!
    Unfortunately Alabama to California is about as far as Canada to Mexico. Sorry I can't help you with where to buy.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Raising CH
    What is the CH level in your fill water?
    Welcome to the forum
    You're done SLAMing when:
    Re: Raising CH
    Quote Originally Posted by salp
    I use liquid chlorine (12.5%)
    Re: Raising CH
    Quote Originally Posted by Butterfly
    130
    Guest
    Re: Raising CH
    CH fill rate is good, I would still let it raise on its own overtime. TA should also rise with aeration. What is your current CSI #'s?
    Guest
    Re: Raising CH
    By your screen name I have a pretty good idea where you are located (or at least a good guess!). If I am correct, I'd leave it alone. Trust me; it will come up all by itself!
    Welcome to the 'page!
    Re: Raising CH
    It's at about -0.3 right now. My pool is about 10 years old. My fill pH is over 8, plus with all the aeration, adding MA is a regular part of my pool maintenance.
    I wanted to add CH to get the CSI closer to 0. I don't want to add TA since my pool already has a problem with consistently rising pH and higher TA levels only encourages pH to rise. MA tends to lower TA, so I may have to adjust it higher from time to time.
    Re: Raising CH
    Quote Originally Posted by simicrintz
    I do have to work on my profile. I'm sure you're right about the water, I'm probably over thinking it. Just thought I'd try to hone in on zero for my CSI.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Raising CH
    -0.3 is fine.
