Thread: Is this good
    DeathB4Me's Avatar
    Jun 2010
    Las Vegas, Nevada
    23
    Is this good
    I'm a new pool owner and i kind of been frustrated about the chemistry. i was talking to my nighbor about it and he told me that he only worries about the FC and PH, and he also told me that the previous home owner did the same and never had any problems with the pool.
    Is it good to just worry about that? If it is this would take care of my frustration.
    21K gal, Pentair Cartridge filter, IG pool, Concrete, 2.5hp Pentair pump.
    Jan 2008
    Northeast Florida
    161
    Re: Is this good
    PH and FC are the only values that change on a daily basis. In that respect, they are the only values that require daily attention or "worrying". The other results (CH, TA, CYA, etc) don't change much, HOWEVER it is still important to check them initially to make sure they are in range, and occasionally to make sure they stay there. If TA and CYA are within range, it will be MUCH easier to maintain proper pH and FC. Out of range CH can cause permanent damage to a pool.
    Why are you frustrated? Is there a particular test/result that is out of range or causing you problems? If you post your results we can help.
    33' above ground pool, 52" deep, about 27500 g
    sand filter w/zeobrite
    Re: Is this good
    Quote Originally Posted by Miranda
    CC is also important as it tells you when the shock is needed.
    Intex 18' x 48" < 5,593 gal
    Stock pump/cartridge filter
    Rare actual working hang on skimmer *keeping fingers crossed*
    Jan 2008
    Northeast Florida
    161
    Re: Is this good
    Quote Originally Posted by 1jjtroutbum
    Good point..but correct me if I am wrong.....if you maintain adequate FC levels, your CC should stay close to zero and you really shouldn't need to shock at all.
    Re: Is this good
    Should have stated that I agreed with you but that CC is also important.
    The 5yo niece and 2yo nephew were over yesterday guess who needed to shock the pool today?
    Re: Is this good
    You still want to know TA, as controlling that will help control pH.
    Most of us want to know CH, as that out of range can affect the pool surfaces.
