Results 1 to 17 of 17
Thread: White line appears after swimming
    Greetings,
    So this summers fun is the white line that appears around the water line after swimming. It seems to heavily concentrate on the mortar around the tile just above the water line. It appears after the pool is used, and the more splashing, the worse it gets. The amazing thing is that it disappears the next morning. I do have an issue with constantly rising ph, but I keep it in check.
    Anyone know what this is? Does calcium disappear over night?
    I have grey mortar so it really shows.
    Any help!
    Southern California/sun all day
    26k gal/in-ground plaster/jacuzzi spillway
    dual speed 1.5/2.5 Hayward
    Cartridge Filter
    UV Ozonator
    Inline Chlorinator
    Wife in bikini and Margarita maker
    Guest
    Re: White line appears after swimming
    Post a full set of numbers so we can determine your pool water chemistry
    Ph 7.9
    Fc: 3
    Cya 40
    Ta 70
    CH 200
    That's all I got
    Cartridge Filter
    UV Ozonator
    Inline Chlorinator
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Your PH is too high.
    Do you use an algaecide?
    Nope, no algecide. Just acid, some chlorine. Pool is pretty Chem free
    Cartridge Filter
    UV Ozonator
    Inline Chlorinator
    Ph is a constant battle, always has been. I do have a spill way out if the jacuzzi, but can't turn it off as it is part of the filter circulation.
    Cartridge Filter
    UV Ozonator
    Inline Chlorinator
    Feb 2008
    Denton, TX
    5,061
    I'd lower your pH to around 7.4. I'd also get your FC up a bit. You are at the bare minimum.
    Unless the white line is caused by a product that has been applied to the skin prior to swimming, I'm not sure what it could be.
    Guest
    I get it in my spa more often then my pool (Probably cause of the heat). When I lower my PH to 7.2, it goes away.
    Ok, i have real trouble keeping the ph down. I have to pour a gallon of acid in everyday.
    Could it be effeflourence(sp?)
    Cartridge Filter
    UV Ozonator
    Inline Chlorinator
    30,432
    Well, in a pool your size, and assuming your pH is 8.0 when you decide to add the gallon, that would mean your pH must be getting down into the low 6's each day. Is that correct?
    No, it drops to 7.3-7.5 range. And then shoots back up to 8 in 24 hours
    Cartridge Filter
    UV Ozonator
    Inline Chlorinator
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    How are you testing? That seems impossible without sky-high TA.
    Tf 50 kit, my ta was high earlier this summer. Do you think it could have something to do with the ozone bubbles that come out if jets?
    Cartridge Filter
    UV Ozonator
    Inline Chlorinator
    I am gonna retest and get back with more details. Thanks
    Cartridge Filter
    UV Ozonator
    Inline Chlorinator
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    what strength MA are you adding when you pour in a gallon at a time? Even at 20k gallons, that's a lot of MA to dump in the pool at once.
    Jul 2009
    Seattle, WA
    89
    How old is your plaster?
    20,000 Gallon kidney sort of a sand filtered gunite in ground pool w/ hot tub.
    30,432
    Hello-o-o-o, Sausage!! Are you out there?
