Thread: How to drain pool after rain??
    Hi All,
    we received abt 2.5" of rain sat and i drained the pool a bit the only way i know how, the backwash procedure.
    so we are getting more rain now! i dont want to backwash again as i dont want to wast the DE from the filter.
    We do have a "hose bib" right near the pump.
    what is the proper way to drain the pool a bit using this? do i just hook up a hose and turn it on while the pump is on or is there more to it?
    thanks!!
    Eric
    Guest
    Re: How to drain pool after rain??
    Hook the hose to the hose bibb and away you go!
    You have figured it out already. Hook up a garden hose, turn on the valve, and the pool will drain (so long as the pump is running). You want to keep an eye on the whole process, so you don't drain too much, and remember to turn off the garden hose valve before turning off the pump.
    thanks!!!!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    What the heck is a "hose bib"!
    Dec 2009
    Central Massachusetts
    2,690
    Quote Originally Posted by woodyp
    The valve that you screw your garden hose onto is called a hose bib, or a spigot, or a sillcock, or a hydrant.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
