Results 1 to 12 of 12
Thread: HTH 6 WAY STRIP NUMBERS. HELP
    I use the Pool Calculator and am getting these recomendations:
    TH 200= nothing
    FC 0 = add 1 qt, 1 cup and 6 ozs 6% bleach
    PH 8.4 = add 15 oz of 34.8% braume
    TA 250 = nothing
    CYA < 30/50 = add 10oz by volume stabilizer (Note: yesterday it said to add 2.6 oz of stabilizer, which I did about 10 am in the am yesterday).
    I am new to pools and don't think i've ever got it balanced. So far the only issues I have had with it was some cloudiness and it's gone.
    Lost the CYA, when the water got accidently vacuum out overnight last week (Hubby tried to fill it up before I found out. LOL)
    I know, I need to get the test kit TFP recomends, just can't afford it right now. Can anyone help me understand these test trips?
    THYIA.
    AGP, POPUP, 3800GAL. SWG 2000 GPH pump. Over the wall skimmer. SE TX. NEWBIE
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: HTH 6 WAY STRIP NUMBERS. HELP
    The only thing they are probably accurately telling you is that the ph is high. That's about all they are good for. Adding the acid is a good idea...do you already have the muratic acid and can verify the % strength? There are a few options out there so you want to make sure you are calculating carefully. With TA high, you should target 7.2 for your ph.
    What about the 6-way drop test kit from Walmart ($20) is that a possibility? At least it would be more accurate than the strips.
    I wouldn't do anything else with the stabilizer until we know more. The strips are worthless for measuring CYA.
    What chems have you been adding, and how do you chlorinate daily?
    What was your target for FC to arrive at 1 qt?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    If you have to use test strips, then repeat the test 3 times 5 minutes apart, and see if you get repeatable results. Even then don't trust things too much, be very careful adding CYA since the only way to remove it in most situations is to drain and replace water. (also remember CYA can take up to a week or more to show on on tests).
    Ike
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Quote Originally Posted by bunedockmama
    this is 31.45% (20o Baume) Muriatic Acid
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Quote Originally Posted by frustratedpoolmom
    No, I do not have any M. acid.
    Yes, i can afford that for now.
    The only thing I have added, other than bleach, daily ( about 3- 4 cups) is the stabilizer, yesterday
    2 is ok, I think?, but I was gong for 6 just in case. But 2 on the strips? Or on the t=100?
    Thank you for your help, I just hope I am making any sense at all.
    Quote Originally Posted by Isaac-1
    Ike
    Thank you Isaac, I had forgotten that.
    Quote Originally Posted by svenpup
    I'm sorry, I must have miss read it, I will go back and look again. Thank you.
    And too everyone, thank you. I truly don't know what I'm doing, but trying to start with the TFP method is the way I want to go
    11,969
    2 is the same regardless of the testing method...
    2 is fine if you are treating a freshly filled pool with clear water. Then at night you would target say 4 to keep you above 2 the next day. Does that make sense? How does your water look?
    Do you know how much stabilizer you added day before yesterday? Was that the only time you added stabilizer? Have you used tablets or granular "shock" at all?
    Once you purchase your MA, make sure you have the correct strength chosen from the drop down menu, then calculate the proper amount based on the % strength. Adjust your PH first.
    The drop kit will be more accurate and it can test your CYA. There is enough reagent in there for two tests. So we can help you figure out approximately where it is now and then test for it in a week or so... to save reagent. It can take up to a week for CYA to fully dissolve and register, so don't test for it yet, but we should be able to figure out a guestimate level based on how much you added.
    Let us know how it goes, post back if you have any questions.
    Good morning.
    I just read your questions Frustratedpoolmom.
    I added 2.6 ozs of hth granule stabilizer, in a cut off pantyhose foot. I hung it under the return jet.
    As far as the chems we used when we first set the pool, I think Hubby added everything the start up kit said, plus some algecide (SP).
    Then the pool was mostly drained accidently over night last weekend. So basically started out with fresh water. I haven't added anything other than the P.C. chart said of bleach and the 2.6 ozs of stabilizer since the refill.
    I need to add bleach right now as it is at zero, I didn't add any last night because I was getting good advice here and didn't want my readings to change till I understood everyone's answers. I sure do appreciate it.
    I live about 30 miles from any stores to get what I need. Hence the name Bunedockmama. LOL.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    What part of SE Texas are you located in?
    Ike
    Ike
    I'm about 65 miles north east of Houston, TX in the Sam Houston National Forest and I have alot of pine trees.
    Edited to add: We get water from a co-op water company well water.
    11,969
    2 lbs, 6 oz or 2.6 ounces? 2.6 ounces would only raise your CYA to 5, you want it to be at least 30.
    Get your PH down today if you can.... pick up that test kit and some bleach and "ph down" if you can't find Muratic Acid and then we'll help you get this figured out!
