Results 1 to 7 of 7
Thread: how to repair cut cable for pool light?
    Jun 2010
    Sachse, TX (near Dallas)
    8
    aaargh... its been one of those months.
    We were finally getting the sprinklers fixed after the pool installed and the sprinkler guy accidentally cut the cable/cord for the pool lights. It was buried underground in a pvc pipe and they cut right through it.
    We've had one company come out here and they said we couldn't repair it, the whole light would have to be replaced and that per "code" they couldn't take the old one out (we would have to do it) and then they could put in the new one. They said it would be minimum of $600 to get the light replaced, as it is one of the pentair fiber optic one
    Has anyone had this happen? Can we really not just splice the darn thing back together? The cable is a #8 cable, which I believe denotes thickness.
    Guest
    Re: how to repair cut cable for pool light?
    If it is a regular light (110 volt), you do need to replace it completely, as you cannot have a splice in a pool light (nor do you want to ). Fiber Optic is completely different and carries no electrical current, but it does not splice (the light cannot travel through a splice).
    How long is the light cord (from the pool to the J-Box)? The price is a little high..........
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Lest you think Bruce is just giving you the industry line, the wire can't be spliced. Code requires a continuous ground wire to the panel.
    Guest
    Or at least to the J-Box.
    22,551
    Just to give a third comment. The electrical cabling cannot be spliced. However you said they were fiber optic lights and I highly doubt that the wiring running to the light is #8. It sounds like they cut the fibers. While splicing fibers is possible it's usually not something you want to do. Done properly, splicing fiber is more costly than replacing it.
    Let us know whether it's the copper or the fiber that was cut.
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    421
    Let the electrician's turn their back and not listen.
    One you can splice the wire to a Jbox at the cut.
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
    Dec 2009
    Central Massachusetts
    2,690
    Quote Originally Posted by blakeusa
    I'm not sure I understand what your saying.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
