Thread: How to add CYA to an Intex Pool?
    MrsFusion's Avatar
    Jul 2010
    SW Iowa
    80
    I'm new here and been reading all the very helpful info. I've read many threads, but, haven't found the answer to my question.
    I need to add CYA to my pool. But, I learned from reading thread that just pouring the granules in the pool is bad. Read that you could put it in the surface skimmer, also read that you could put it in a sock(not sure what kind of sock)? I ended up putting it in an old sock and placing on a step in my pool. My filter is running...read to leave filter on for at least 24 hours whenever adding anything to the pool.
    My question is...
    Can I pour the granules directly into the surface skimmer? Not sure if it works the same for Intex pools.
    Thanks-
    Amy
    5,000 Gallon 16'x 48" Intex Ultra Frame, Waterway 1hp sand filter, Intex SWG, AquaCritter, TF100
    Climate/Location: SW Iowa
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: How to add CYA to an Intex Pool?
    The sock method is to put it in a sock and hang it in front of a return. You can massage it periodically to help the process along. It can take up to a week to show up on a test.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    MrsFusion's Avatar
    Jul 2010
    SW Iowa
    80
    Moved it! Thanks!
