Results 1 to 10 of 10
Thread: Gulf Coast
    Gulf Coast
    Anyone have any dealings with Gulf Coast Spas? I am looking at buying a used Sarasota model. Its about 5 years old. Im going to look at it tomorrow night.
    Any input would be great
    Thanks
    Laura
    19 X 39 gunite freeform, sand filter, Whisperflo 1.5 HP pump
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Gulf Coast
    Don't know if you're still looking; sorry nobody responded. If you search for some threads on buying a used spa, you can find some good information about what to check.
    Re: Gulf Coast
    Thanks Melt. I have decided to go with a soft sided tub so there is no need for Gulf Coast info anymore
    Laura
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,077
    Re: Gulf Coast
    Can you post a pic of your soft sided tub? Also specifics like make and model. Thanks
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    Re: Gulf Coast
    This is the model Im looking for.....http://www.softubcanada.com/softub-220.asp
    Laura
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,077
    Re: Gulf Coast
    Thank you for the info. I wonder how long this will last and how reliable and durable etc. Please keep us updated if you purchase this.
    Thanks
    Aug 2007
    Eastern Canada
    54
    Re: Gulf Coast
    Quote Originally Posted by Brentr
    Thanks
    I have had a Softtub 220 for 15 years. I had it re-skinned about five years ago as the vinyl was getting a bit scratched, and now the cover is sagging a bit and may eventually need replacement, but it continues to work well. They retail for somewhere in the neighborhood of $3000 to $3300. All you do it plug them into a 15 amp 110 v circuit, add water and chemicals, and you're in business. We run ours year-round with an upper deck keeping the snow and ice off it. Cheap to run - about $10 a month for electricity. You can move it easily, by using a screwdriver to disconnect the pack on the side that contains the pump/heater, and rolling the empty tub anywhere you want. Weighs about 65 lbs so you can easily get it on a pickup to move it to the cottage for the summer. The 220 is for four people. They also offer a six person version.
    18X36' 25000 gal Jacuzzi vinyl Inground Pool (1985) with resin sidewalls, newer Jacuzzi 1 hp two-speed pump and sand filter. Raypak propane heater, Rainbow 320 chlorinator (mostly use bleach).
    Softtub 220 portable hot tub.
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,077
    Re: Gulf Coast
    Quote Originally Posted by derekm
    Thanks
    Derekm, how hot does the water get and how long does it take to get hot? Have you had any problems with the pumps etc. We would probably be interested in the smaller one as it would be used by DW and I. Thanks in advance
    Aug 2007
    Eastern Canada
    54
    Re: Gulf Coast
    The water gets to 104 fahrenheit. It takes about 30 hours to get it up to temp from well water temp, so I fill with water from my hot water tank to get it up to temp a little quicker. Another possibility in the summer would be to pump over some 80 degree water from the pool. Heatup time is not a big issue as I only drain and refill twice a year, and do it overnight on a weekday when I am not planning to use it. I keep it heated 365 days a year, so it is always up to temp except at water change time.
    No problems with the plumbing, but had to replace the logic board once, and the GCFI on the end of the cord another time. Also, be sure there is nothing else on the circuit, as this thing uses most of the 15 amps.
    Re: Gulf Coast
    Picking it up this weekend I hope!!
    derekm
    how much was the board replacement? How much was the liner replacement.
    Laura
