Thread: Salt and Borax
    Jun 2010
    San Antonio
    424
    Salt and Borax
    Is there any disadvantage or advantage to using both 2000ppm salt and 50ppm Borax? I am not using a salt generator, just thinking about adding salt for the feel of the water.
    Larry
    Larry in Texas
    Above ground 7,700 gallons, 19 inch sand filter ( 2 sq. ft.), Liquidator, and a WaterWay Hi-Flo Pump with an A.O. Smith 1 hp SF 1.0 motor.
    Feb 2008
    Denton, TX
    5,061
    Re: Salt and Borax
    The 50 ppm of borates does reportedly have some algaestatic properties. Always a good thing there.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: Salt and Borax
    Just the advantages/disadvantage of using each separately. Both give a subjective improvement in water feel. Borax gives an algaestatic benefit and stabilizes pH. At 2000ppm of salt the increase in corrosiveness is negligible.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
