Thread: Algae or not?
    Lehigh Valley, Pennsylvania
    71
    Algae or not?
    Today I noticed a darker discoloring along the bottom of my pool where the botton ond side seam together on a slight angle (those familiar with vinyl liner pools know where I'm talking about). Otherwise, water is clear and clean. My first thought was algae. Being new to pool ownership I thought I would throw it out. Anyone have any thoughts on if this is likely algae or not? Can algae be present like this in an otherwise extremely clean looking pool? I brushed it off and jacked up the bleach slightly higher than normal (but not near shock level). Should this be sufficient treatment (assuming it is algae)?
    Rob
    25K gal vinyl inground, 1HP Hayward Pump, Hayward DE 4820 Filter
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,575
    Re: Algae or not?
    An overnite FC loss test will tell if it was sufficient or not.
    1ppm loss or less equals good to go.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Algae or not?
    Please post a full set of test results and as woody mentioned, you can confirm with an overnight FC loss test. If you loose 1ppm or more overnight, you should shock.
    71
    Re: Algae or not?
    I did an overnight FC test last Thursday/Friday with no loss. Didn't take a test yet today, but results have been:
    FC-target of 5 but usually dropped to 2 within a day when I was replenishing bleach
    CC-0
    TA-120
    pH-8.0
    CYA-40
    CH-65
    Apr 2010
    East Texas
    9,575
    Re: Algae or not?
    that's a normal FC loss with sun and swimmers.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Algae or not?
    your PH is too high (unrelated to your question, I know)
