Results 1 to 7 of 7
Thread: bromine problem
    bromine problem
    I WAS WONDERING IF ANYONE ELSE USES AS MUCH BROMINE AS I DO????? I HAVE APPROX. 25,000 GAL IN-GROUND POOL & I GO THROUGH 25LBS. OF BROMINE EVERY 3 WEEKS. A FRIEND OF MINE HAS THE SAME POOL AND HAS ONLY GONE THROUGH 50LBS. THIS SUMMER. SHOCK EVERY SUNDAY. MY BROMINATOR IS ALSO SET ON 1, THE LOWEST SETTING. POOL IS ALSO 2 1/2 YEARS OLD. ANY HELP WILL BE GREATLY APPRECIATED.....P.S. I WAS TOLD BY A LOCAL POOL COMPANY THAT I COULD USE A CLORINE SHOCK & I DID........
    Dave
    25,000 gal inground PebbleTech with attached spa and water feature. Cartridge filter.
    divnkd101's Avatar
    Mar 2007
    Pearland, TX (Houston Suburb)
    587
    Larry,
    Welcome to TFP. Please post your question in only one section. I promise someone will be along shortly to answer your questions. I have deleted your other (identical) posts. Thanks again for joining.
    MIKE
    21K Inground Custom w/ Spa (Gunite/Plaster), SWCG, Hayward Northstar, Polaris 280, Hayward Color Logics, Jandy PS-8
    SORRY NEW TO THIS THING!!!!!!!!!!!!!!!!!!!!!!!!
    Dave
    divnkd101's Avatar
    Mar 2007
    587
    Nothing to be sorry about. I just want to make sure you get the answers you are looking for.
    MIKE
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Larry, is your pool outdoors or indoors?
    Guest
    Bromine cannot be stabilized against burnoff from sunlight so if you have an outdoor pool that gets a lot of sun your bromine levels will drop quickly. You can reactivate the bromne by shocking with chlorine. The chlorine oxidizes the bromide ions in the water back into active bromine santizer and gets converted to chloride ions in the process.
    What bromine levels are you maintaining in the pool?
    Also, typing in all caps is usually considered to be the equivalent of shouting on the net. Proper nettequite usually reserves all caps for EMPHASIS ONLY
    the pool is outdoor. i keep it around 2-3 p.p.m.
    Dave
