Results 1 to 8 of 8
Thread: water evaporation rate formula ??
    Jacksonville, Florida
    18
    Anyone ever heard or know of an acurate formula for calculating evaporation rate of a pool ?
    I am certain it depends on air temp, water temp, RH, agitation, air movement, disolved solids in water, etc, so I am sure it isn't an easy one, but this has really peaked my curiosity, especially here in NE FL with the drought conditions (RH between 20 and 25% with highs at 88 to 90) I have watched the water level drop almost 2 inches in less than a week. I do not have any leaks, and haven't backwashed (used the bucket on the ladder trick to verify)
    any thoughts ?
    figured this was a "geeky" question so I posted it here in the chem side...
    12k Inground pool, Pentair Intelliflo 3hp Variable Speed pump, Heliocol solar panels, suntouch solar controller, Aquarite SWG.
    East Tennessee
    278
    I think a that would be hard to predict and the math would change day by day. You may want to think about using a cover of some type to prevent evaporation.
    Steve
    Echo Canyon II by Artesian Pools, 13.5 KGal AG Round, 22" Artesian Sand Filter 2 hp Artesian pump
    Med Lab Tech for 12 years in E.TN
    Chem testing by Trouble Free Test Kits
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Pretty tough one to calculate. You'd have to consider humidity, wind speed, air temp, water temp, cloud cover, maybe even sun angle among other things. You'd have to update the calculation as conditions changed.
    18
    there in lay the challenge !!!
    I have found a few sites that discuss this, but I am not a scientist, nor chemist, so I mainly pose this question for theory and discussion. I am aware the only way to prevent, or at least slow down evap is to cover, I was just pondering if anyone had seen or developed a formula that took to count the above mentioned variables, and a few we may not be considering. (i.e. disolved solids, ph, etc.)
    Mar 2007
    San Rafael, CA USA
    12,082
    MarkS at the Pool Forum posted this link that gives evaporation rates in different areas of the country. These are annual rates so the rate in summer is likely to be much higher than that in winter, but at least it's something -- it seems that the Class A evaporation values are for May through October so perhaps this is closer to a summer season rate. It should be noted that the evaporation for water in a swimming pool will probably be less than the pan evaporation rate since the pan rate is high due to the metal pan getting hot from the sun. This is why the evaporation rate for lakes is about 75% of the pan evaporation rate. On the other hand, pool water is typically heated and may be warmer than air temperature or certainly warmer than it would be if kept in a pan for 24 hours a day. So maybe the pool evaporation rate is close to the pan evaporation rate.
    KurtV's Avatar
    Mar 2007
    SE Louisiana
    270
    Quote Originally Posted by chem geek
    Interesting information, Richard. I'll bet that in my area of the country (Gulf Coast) the rate doesn't vary much from Summer to Winter as the temperature and humidity tend to track together (e.g. cooler but drier air in the Winter vs. warmer, wetter air in the Summer).
    That site also makes it easy for me to convert the water level drop in my neagtive edge trough to the equivalent water levl drop in the pool. Thanks.
    Fayetteville, Arkansas
    220
    In NW Arkansas with temps in the low 90's and humidity off the chart - I'm losing about half to three-quarters of an inch a day
    in a 30,000 gal.
    20x40 30,000 gal IG Liner, Pentair II Sand
    Once when we lived in another house I had deer that would come and drink pool water, and for a good while, I was chalking it up to evaporation.
    If it doesn't rain (and give me more metal free water YAY) soon I am going to have to add more water, we are down about 2 1/2 inches this week with over 90 weather, and lower humidity and a good bit of wind. I only have 6000 or so gallons though. No deer, but I did have a couple of horses from down the road in the yard this AM...
    Fort Wayne IG Vinyl 18 x 36 (22,000 G)
    3/4 hp Pentair Pump
    Sand Filter
    Polaris 280 w/ booster pump
    No heater yet...solar cover
    Mount Airy, NC
