Thread: Aquabot Turbo drive motor
    Anyone familiar with the difference between the A4510A and A4510T drive motors? I have an Aquabot Turbo and the drive motor (which was supposedly replaced about a year ago) is a 4510A that just stopped working. I'm not sure which motor to replace it with, or if having the wrong motor installed (if it is the wrong one) could have led to such an early failure. Thanks.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Aquabot Turbo drive motor
    woxall, welcome to TFP!
    I don't know the answer to your question. My first thought would be to check the manual (they may have a part # listed for the motor) or to just call the manufacturer. I hope you get it figured out!
