Results 1 to 10 of 10
Thread: Should have...?
    Should have...?
    Hello,
    We are going with a fiberglass pool and have made our selection on an installer. I have range of 30-35K but would like to know what those with existing pools would have or should have done differently at the time of the install? Any features you wish you would have added? Any that you did add that you don't feel was worth the extra cost?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: Should have...?
    Check the prevailing winds and put a skimmer as far downwind as you can. Mine is on the side, but the wind blows debris right past it.
    Heckpools's Avatar
    Feb 2009
    New Jersey shore
    318
    Re: Should have...?
    Quote Originally Posted by Richard320
    YES!
    If only the builders thought like that
    [center:3gj9kdnn]Matt Heck
    "HECK OF A POOL SERVICE LLC"
    Serving Ocean co. NJ
    COMPANY INFO BELOW
    http://maps.google.com/maps/place?hl=en ... 2995187987[/center:3gj9kdnn]
    Heckpools's Avatar
    Feb 2009
    New Jersey shore
    318
    Re: Should have...?
    id say unless you have the extra money to spend, most upgrades arent worth it. Maybe a heater.
    if you have some extra cash, throwing in a color logic light would be cool. um... ok and a waterfall lol
    COMPANY INFO BELOW
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Should have...?
    "Oversize" all in ground plumbing and run extra underground wiring for potential future electrical/lighting upgrades.
    Ike
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Should have...?
    If you can afford it and have space, get about twice as much decking as you think you need.
    Sep 2008
    The Woodlands, Texas, USA
    243
    Re: Should have...?
    Put the pressure side cleaner connector on the deep end so the cleaner sinks out of the way when not in use.
    Oversize plumbing (pipe diameter) yes!
    Put 2 returns over every step or tanning ledge to help clean them.
    Add one extra return on the deep end about half way down for better water circulation and reduced stratification.
    If it works for your climate buy a heat pump for heater or add solar (extra solar).
    IG 24k plaster with overflow spa. Goldline PS-8 SWG. Tristar 0.75 HP filter pump, Polaris 280, large cartridge filter, 400k BTU NG Max-E-Therm HD, SR Smith Turbo Twister, Life Saver pool fence, ORP managed.
    Sep 2008
    243
    Re: Should have...?
    Saltwater chlorinator!
    Re: Should have...?
    Wow!
    Thanks for all the feedback and great ideas.
    Sep 2009
    Frederick County, MD
    184
    Re: Should have...?
    Great topic!
    We just completed our fiberglass install and here is what I wish we would have done.
    - Waterline tile
    - Some sort of water feature
    We have Leisure Moroccan 38 and our builder offered a small waterfall that looked like a thin slit that would have looked great where my pool curves in. He wanted $650 and by that time we were so over budget that I could not tolerate the additional expense. Same for the tile. Looking back, I really wish we bit the bullet and did them both.
    Jim
    Southern Frederick County, MD - Leisure Moroccan 38 Fiberglass Pool - 19,800 gallons
    Pentair 1.5 hp 2 speed pump - Cartridge filter - Dolphin robot - TF-100 Test Kit - SWCG
