Results 1 to 8 of 8
Thread: Anyone know whats in Pathmark Home basics bleach??
    Central NJ
    44
    I bought bleach at Pathmark here in NJ and it was $1.69 a gallon. It says nothing about the concentration on the bottle. It has a yellow label that says HOMEBASICS BLEACH. Made in Canada and dist. buy on-point in Montvale NJ.
    My pool had .5 FC reading and after adding 44 oz to 6200 gal pool the FC was higher then 5. My test only goes to 5 and I am thinking around FC 7 because it was way darker then FC 5 on the test tube comparison. I put 44 oz in the pool calculator and the only way it would be FC 7 withh 44oz if it was 12.5% bleach.
    COULD THIS BE?
    12X18 AG, 6200 gal
    Hayward S166T sand filter, Switched back to 100 sq ft cart.
    Hayward 1hp power flo matrix two speed pump.
    Been using BBB since pool was new in 2004. Never had any problems.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,031
    Re: Anyone know whats in Pathmark Home basics bleach??
    I suppose it's possible. If so, I'd go buy a month's worth at those prices!
    I believe they underrate bleach knowing it will lose some strength just sitting in warehouses and on the shelf. This time of year, it moves faster, so it hasn't had time to degrade. But double strength seems like overkill.
    If you have the FAS-DPD test you'll be able to tell exactly how high your FC goes. You could try diluting your sample water 50% with some distilled water and see what you get then; it won't be entirely accurate, but better than "off the scale."
    Central NJ
    44
    Do I times the reading by 2 then?
    12X18 AG, 6200 gal
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Yep. Diluting the sample 50-50 with distilled water will mean that the reading you get is half of the actual value. It also means that the accuracy is cut by half as well.
    So the bleach doesn't list any ingredients at all? Does it smell like regular bleach?
    Central NJ
    44
    It next yr yeah!!! I still found that bleach. No #'s on to tell the strength. Its down to $1.48 gal regular price.
    Can I use RO water instead of distilled to dilute the test 50/50?
    12X18 AG, 6200 gal
    Yes, RO water is chlorine free so it is fine.
    Central NJ
    44
    Oh is that why..Duh.. I am on a well. I can just use out of the tap?
    12X18 AG, 6200 gal
    Chlorine free is the crucial thing. I would use the chlorine test to confirm that your tap water has zero chlorine as a double check first, just because some people have systems that add chlorine to well water.
