Thread: AO Smith Century Two-Speed Wiring Issue
    We are currently in the process of building a pond, and really don't want to hire someone to come out and wire this little motor for us. The motor's CAT number is B2981, and it has 3/4 HP. We've gotten the electrical box open, but AO Smith's wiring information is a little bit shotty. Once again, it is an AO Smith Century two-speed split capacitor motor/pump.
    If someone is experienced in dealing with this motor's wiring, or can point me to some sort of diagram, I'd be thankful.
    Jun 2010
    Fremont, CA
    293
    Re: AO Smith Century Two-Speed Wiring Issue
    There is a tiny bit of wiring info at the bottom of this website:
    http://www.electricmotorwarehouse.com/4 ... flange.htm
    Jeff
    40 x 16 (28k gallon) plaster pool, Intelliflo VF pump, Hayward 48 sq. ft. DE filter, using Purifiber, using BBB, TF-100 test kit
    22,548
    You should have three terminals in the pump, L1 L2 & A. Neutral shoud go to L2 (com) and hot should hook to A for low speed and L1 for high speed.
    What are you trying to wire it to? A switch or a timer?
