Thread: Jandy RS6 One touch- Temp sensor
    Just installed a Agualink RS one touch. All appears ok but temperature sensor information on control panel show "sensor short" when in spa mode but the pool mode shows correct temperature--- any idea what is going on and what solution is?
    thanks
    15000 gal 16x30 fiberglass inground w/screen inclosure, 1 hp Hayward pump, Hayward cartrage filter.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Jandy RS6 One touch- Temp sensor
