Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: When to put the pool decking in?????
    I live in Massachusetts and am almost done with my pool installation. Liner and water go in this week. The pool company is telling us that we must wait at least 3 weeks before pouring the deck/cement patio. That gives enough time for the ground to settle. But every single person I talk to who has a pool says WAIT till after the winter! They say do it next Spring because waiting it out through a winter will help prevent cracks. When I tell the pool company this, they say that you don't have to wait; concrete cracks at some point no matter what. And, that they pack the ground so hard, that 3 weeks is sufficient. And if I don't do it within the 3 weeks, they make me sign a waiver that their not held responsible if anything happens to pool structure due to the decking not put in yet. They say the decking helps stabalize the pool as well. 3 pool companies here have all the said the same thing. And what do they care? they are not doing the cement... another company does that.
    But when I speak to my neighbors and friends who have a pool, they say wait!
    So, now I don't know what to do. I am wondering if anyone up North has advice on what I should do???
    76549 Liters -- Cartridge Filter -- In Ground -- Vinyl -- TF-100 Test Kit -- AquaVac Robotic Cleaner -- UV Sanitation -- Winter Safety Cover -- Installed 2010 -- Southwestern Ontario, Canada
    Latest Test Results June 25:
    FC - 6, CC - 0, CYA - 40, CH - 110, TA - 90, pH - 7.5
    Dec 2009
    Central Massachusetts
    2,690
    Re: When to put the pool decking in?????
    I finished mine on september 9th. I didnt put in the decking until the following June. My 2 neighbors didnt put theirs in until the following spring either. And, we all used different pool companies. Even my pool builder said dont put it i until the spring. I wouldnt sign any waiver, I dont care what they say. The deck does not stabilize the pool, only the backfill does that.
    I live in central mass. Where in mass are you?
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    30,432
    LIsten to bk406. The longer you can wait, particularly over a freeze/thaw cycle, the better off you are.
    I was able to wait a year on mine (I know that's excessive) and 7 years later still don't have a single crack. I'm sure it will sometime down the road but I've enjoyed having 2500' of crack free decking thus far.[attachment=0:3j5nlppf]temp054.JPG[/attachment:3j5nlppf]
    Dec 2009
    2,690
    Mitch,
    You have a PM. Check in the upper left and click on the new messages text.
    Thanks for your responses. I've got to wonder though... why do all the pool companies up here say do it within 3 weeks. I had 3 pool companies bid on my pool and all said the same thing. And they aren't doing the decking. If I wait till the Spring, is it best to wait for the fence too? What a pain... don't want to do the fence till the decking/layout is done. Should have done my pool in September. Technically though, the kids can still use it. People say just put the green carpet down.
    Dec 2009
    2,690
    I'm not sure who the 3 companies are that are telling you to only wait 3 weeks. For my money, there are only 2 vinyl pool companies i would do business with and both of them would tell you to wait. A deck does not stabilize a vinyl package pool, period.
    Bottom of contact says:
    The Contractor recommends the installation of a concrete deck of at least 3 feet minimum around the entire circumference of the pool within 3 to 6 weeks of pool installation to complete the monolithic integrity. Owner acknowledges the contractor has explained the importance of the concrete deck and understands the contractor or manufacturer will not be responsible fo rany damage such as cracking or impressions to the pool floor caused by surface water due to the unitmely installation of the conrete deck.
    Dec 2009
    2,690
    I've never seen this type of thing. I had 3 guys bid mine and none of them said this. All said to wait.
    I installed in October and poured concrete the next April. That was on the advice of my PB
    However I don't know if your more extreme winters would make a difference or not.
    I would wait as long as possible. Three weeks is not very long and if it doesn't rain to help settle the dirt it doesn't matter if its 1 day or three weeks anyway.
    18' x 36' saltwater inground vinyl pool
    Dec 2009
    2,690
    Quote Originally Posted by ouachita
    No, i'm in massachusetts too.
    If they don't pour the decking... why on earth do they care then?? 3 pool companies all say do it within 3 weeks. Although they all did say a few years ago, yes, they advised to wait... but not anymore. And, I wonder why???
    Dec 2009
    2,690
    If the pool is built correctly, you could go years w/o a deck
    For all of you who waited till the Spring and have a fence around the pool... did you wait to install the fence too? Is the orange construction fence sufficient/up to code during the wait? Want to do my fence AFTER my patio.. but not sure if that's legal.... let alone safe!
    Dec 2009
    2,690
    Orange construction fence is not to code. I did my fence before my deck, but i did pavers. If i did do concrete, it would have been pretty easy. If they cant get a truck in the back, they can use a mud buggy, or pump it from the street.
    I'm also curious what they are going to backfill your pool with.
    They will backfill with the ground they dug up... as it's all around the sides. Can I attach a picture or do I need to create a URL to the picture?
    Some pics...
    The picture without the liner was last week (before they poured the concrete inside). The liner pics are from today!
    Malibu07's Avatar
    Jun 2010
    Southeast VA
    207
    Quote Originally Posted by mitch10196
    I'm getting ready for my pool to be put in sometime this week. I asked the excavator what they were going to use for the back fill, he said it all depended on what came out. See where I live it could be either sand or clay. If it's clay, they'll mix it with sand and dirt.
    As soon as they start, I'll get some pictures up.
    14,700 gal. 14 x 28 rectangle with 2R IG by Hydra Pools, 1 hp Hayward Maxflow ll, Hayward 24" Sand Filter, Aquarite Electronic SWG, one Aqua Genie Complete Skimmer, two main drains, four returns, 2 spa jets in steps, 30ml Tidewater liner. Taylor K-2006 Test Kit
    Dec 2009
    2,690
    They put water in it before they backfilled?
    Did they pour a concrete collar around the outside?
  20. Back To Top    #20
    Aug 2007
    near the swamp
    806
    all pools here are completed in 2-3 weeks
