Thread: bromine coverting to chlorine
    I am currently using bromine for the first time in my new pool . Besides the cost factor I am not sure if it is as effective as chlorine which I have always used in my old pools . I am looking to convert from bromine to chlorine , I have a gunite in ground pool .Any advice would be great .
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: bromine coverting to chlorine
    Larry Mag, welcome to TFP!
    Converting from bromine to chlorine is very difficult. Essentially, you have to do a 100% drain to get all of the bromide out of the pool. How long has it been operated as a bromine pool? If it hasn't been too long, there may not be too much bromide in the water and it could be possible, though still difficult.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Where are you located? A complete drain does have some issues if you have a high water table where you live.
