Results 1 to 7 of 7
Thread: Unable to get Chlorine Readings
    Apr 2008
    Arkansas
    13
    On Monday June 28 tested using TFT Test Kit and got the following readings;
    0 FC
    .5 TC
    .5 CC
    95 TA
    7.6 PH
    108 CH
    40 CYA
    Just to verify took sample to pool store and my readings and Pool Store were right in-line except for CYA they showed 19. AT their suggestion I added 3 lbs of stabilizer waited 12 hours, tested CYA again and I show about 55 CYA, then shocked 2.5 lbs turbo shock.
    For the past several days of monitoring chlorine I still get no chlorine readings using either the quick test or the drop test.
    23,000 gal vinyl in-ground pool
    Sand Filter
    1.5 HP pump
    22K Gal double roman IG, vinyl, 300lb Crystal-Flo sand filter, 1 hp Sta-Rite pump, WF on pool side with 1.5 hp Challenger pump.
    benavidescj's Avatar
    Apr 2010
    Fleming Island, FL
    431
    Re: Unable to get Chlorine Readings
    How much chlorine did you add and how long did you wait between water testing readings?
    Carlos
    Pool: 28,000 gallons IG; IC 40 SWG; Pentair 120 gpm cartridge filter; Marble finish; Pentair Wisperflow 1.5 hp; Polaris 360
    Spa: 350 gallon; Bromine
    How to shock your pool
    30,432
    Hey, Kerry,
    Welcome to the forum.
    No, you didn't shock....you simply added a big dose of chlorine. Go up to Pool School and read the article on How to Shock your Pool. You will find it is a process that extends over a period of time and will require multiple doses of chlorine......not just one.
    Please do not use any more stabilizer.....you're as high as you want to be.
    You would be better off calculating how much Clorox to put in your pool to shock (we're happy to help.....you're gonna' need a bunch.....more than you realize) rather than following the pool store advice. Have you found the pool calculator? It's in my sig.
    Aug 2007
    Jackson, NJ
    61
    Also, verify that the turbo-shock you used was actually chlorine-based (probably calcium hypochlorite) rather than sodium monopersulfate. Sounds unlikely that you were given the wrong thing but I have met some really dopey pool store guys (with all due respect). Then, just stick with the advice of the experts (not me, but anyone listed as a Special Contributor is a good bet). Remember, shock is a process, not a product. (I've been wanting to say that, ha! ha! but since I switched to BBB and have followed TFP I have not had to shock, knock wood).
    phil_d
    20,000 gal. vinyl liner pool
    Hayward Perflex EC-65 DE filter w/1.5 hp Hayward Super Pump
    Liquidator w/ 3/8" upgrade
    Aquabot Jr. pool cleaner
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    I did some hunting... Turboshock is Calcium Hypochlorite.
    For a pool your size, 2½ lbs will raise FC 9.4ppm, CH by 6.7, Salt by 0.6.
    IF your CYA is only 55 (test again to be sure), normal FC is 4 to 9. Shock level is 17.
    You got only into maintenance zone once, several days ago, and nowhere near shock level, not even for an instant. Luckily, your CH isn't high, so no harm done there.
    You have the test kit, now you need to read How to Shock your Pool, and load up on bleach. Or liquid chlorine from pool store or Lowes; same stuff just stronger. Get comfortable using Pool Calculator, as well. With diligence, you can have a sparkling pool with balanced chemicals by next weekend.
    Apr 2008
    Arkansas
    13
    Ok, double checked CYA and is 50-55. Added enough cal hypo to raise FC to 16 according to CYA chart. Will test chlorine again in 6 hours. Anyone have other suggestions?
    30,432
    The CH test is only valid in increments of 10. i.e....100, 120, 180, etc. The 108 you posted concerns me that that test is in error. Please confirm your accurate CH results before you continue to use Cal Hypo.
    Once your Calcium levels get too high, they are amazingly difficult to lower.
