Results 1 to 9 of 9
Thread: Pump question
    Pump question
    We just got this free filter and pump so we are swapping out our 100# filter for a 200# one. I wasn't expecting a pump, too, but we got one. Our current pump is one speed 1 HP, the one we just got is two speed 2.5 HP. Which one should we use?
    Sue
    Current Pool: IG Concrete / 11,000 gal. / Sand filter / Solar heat / Hayward CL200 / Screened / TF Testkit
    Pool owner since 2001. Thanks TFP for helping me convert off Baquacil after six years!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    The smaller one. It's already bigger than what you need. Unless the 2.5HP's lower speed and energy use is equal or lower than the 1HP.
    Thanks!
    Sue
    Hey John... I just found out that the 1 HP has an rpm of 3450. but the 2 speed 2.5 HP has an rpm of 1725 on low and 3450 on high. Would you still say to go with the 1 HP? My husband is thinking the 2 speed would be better.
    Sue
    heh... just saw your edit as I was posting the RPMs. So now it's looking like the 2 speed is the better choice.
    Sue
    SW Indiana
    9,199
    Quote Originally Posted by MeSue
    Look at current draw for both.
    The draw for the 2 speed was less on low speed and more on high speed than the one we were using. We ended up switching over to the 2 speed. It is also much quieter, and appears to move just as much water as my old one did.
    Sue
    A two speed pump on low has 1/4 the HP of high speed. So a 2.5 HP two speed is 0.626 HP on low.
    I just got my first power bill since switching from the 1-speed pump motor to the 2-speed running on low. I also switched about half-way into the billing cycle from running it 24/7 (Baquacil) to running 12 hours a day (after switching to chlorine). My power bill was lowered by more than $50. Wow!
    Sue
