Thread: Pool Liner Underlayment
    Jul 2010
    SOUTH FLORIDA
    10
    Just my experience : I installed my aboveground Intex 16' round pool a couple of months ago and used 1 1/2 inch thick styrofoam sheets under the liner. After leveling the ground, I just laid the styrofoam (4 x 8 sheets) down on the ground - taped the seams - put the ground cloth over the top and installed the pool. Feels very smooth and cushy underfoot. The styrofoam only cost me about $50.00
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Pool Liner Underlayment
    Thanks for the tip; I hope it works out well for you!
    Jul 2010
    Layton, Ut
    26
    Is the foam still holding up for you? Next year we want to put a concrete pad for the pool to sit on, so I dont want to WASTE putting all that sand sown only to remove it to pour the pad.
    Are you talking about the Pink or Blue sheets from like Home Depot or Lowes or something? We were thinking about carpet or padding as a temporary underlayment, but that will be pricey. My pool is the 24 foot Intex.
    Intex 24'X52" Round
    2500 GHP pump
    Northern Utah
    13,000+ gallons
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    1 1/2 or 2 inch foam is the way to go. I have been using it for quite a while now. (5-7 years not sure anymore). Do not use the white, use the pink, blue or yellow. What I have done is level the ground, put the foam in place, cover with a heavy duty tarp (I have always used a HD silver tarp not that cheap blue tarp that comes with the pool) and setup the pool.
    Intex Ultra 18' x 52" AG 6,981 Gal.
    3 - 2'x20' solar panels
    Hayward XStream 1500 Cart Filter
    Hayward 1-1/2 HP 2-speed Superpump
    Aquabot Pool Rover
    2-Softub 300 hot tubs (yup just got one for the lake)
    TF Test Kit Doing the BBB for 7 years
    Medota Heights,Minnesota
    Jul 2010
    SOUTH FLORIDA
    10
    Quote Originally Posted by mcoonan
    I actually did use the white styrofoam sheets - but other than that - same / same. Only been a few months but was the most cost effective (CHEAP) way of doing it. Other benefit : feels very soft and cushy underfoot.
    Oct 2013
    Los Angeles, CA
    87
    how is the white foam holding up ??
    Intex 12 by 24, Intex 2600 sand filter (soon to upgrade), deck under construction
