Thread: Dolphin pool cleaner
    The plug on the transformer was pulled out. Nothing is broken. Inside has two wires one is black the other is while. On the plug are 4 places to connect it too. They are numbered 1,2, 3,4. Which one does the white wire connect to and the black wire..thanks.........JOEL
    21K gal. inground with dark colored plaster, spillover spa & rock waterfall
    Jandy DE filter, Aqualink control system,
    non-SWG; switching from automatic feeder of tri-chlor pucks to manually chlorinating with bleach
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Dolphin pool cleaner
    What model of cleaner is it? I know some people here have Dolphins, and maybe someone has the exact same model and can take a look at theirs.
