Thread: Intelliflo VF pump
    Intelliflo VF pump
    Hello everyone new to board. I installed new Intelliflo Vf pump and adjusted contrast display on the pump. Now I cannot read the display at all. How do I reset display to factory settings? Thanks in advance.
    Jun 2010
    Fremont, CA
    293
    Re: Intelliflo VF pump
    Centuri,
    I just installed a VF as well. I can't find a factory reset. But here is the constrast setting sequence from the manual, and I just tested it.
    Press the "Menu" button.
    Press the "down arrow"
    (this should take you to the time/contrast menu, which you cannot see, since I guess your contrast is set too low)
    Press "Select"
    Press "down arrow" to select contrast.
    Press "Select"
    Press "down arrow" about 5 times to get contrast reading of 4.
    Press "Enter" to save the setting.
    Hope this works. Page 22 of the VF manual describes this, and seems to indicate that contrast setting of "0" is for bright sun. So, I'm guessing you set it to "9", and need to go down about 5 times to get something readable.
    Hope this works for you. Let me know either way by posting.
    Jeff
    40 x 16 (28k gallon) plaster pool, Intelliflo VF pump, Hayward 48 sq. ft. DE filter, using Purifiber, using BBB, TF-100 test kit
    Jeff (ride525)
    Thank you for your great instructions, they worked perfectly! Pump is up and running.
    centuri
    Jun 2010
    Fremont, CA
    293
    centuri,
    Yay......
    It took me awhile to make sure I had all the "down arrows" and all the "Selects".
    Glad they worked first time!
    Jeff
