Results 1 to 14 of 14
Thread: currently 26 kids in my pool
    Jun 2010
    Pensacola FL
    40
    There are currently 26 kids in my pool at my last count. This AM numbers were
    FC 6.0
    CC 0
    CYA 60
    Usually I loose 1ppm of chlorine on an avg day. Any bets what my chlorine levels will be when I re- test tonight.
    The closest wins......my admiration
    14.5 K inground vinyl
    1hp pump
    sand filter
    Taylor K-2006
    Aquarite SWG
    P'cola FL
    Feb 2008
    Denton, TX
    5,061
    Re: currently 26 kids in my pool
    2 ppm
    Apr 2010
    Buckeye, AZ 85326
    619
    1ppm
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    30,414
    If they are under 10, you could easily be at zero. If they are under 6, uh-oh!!
    This group (about the same size) didn't use all that much but I have to assume as teenagers they were beyond the "pee in the pool" stage.[attachment=0:2097g59f]Sarah13bday 001.jpg[/attachment:2097g59f]
    Feb 2008
    Denton, TX
    5,061
    So we are supposed to outgrow that?
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Note to self, Mags must wear a leg bag (catheter) if he ever swims in my pool!
    Love TFP? Become a
    TFP Supporter!
    30,414
    Well, you can earn a partial handicap if the adult beverages have reached a certain point. That certain point varies from pool to pool and even from swimmer to swimmer.
    Nevertheless, "Yes, I think we're supposed to have grown out of it"
    Oops, it appears 257 will not be able to earn that handicap....at least, not in zea's pool
    Jun 2010
    Pensacola FL
    40
    most kids under 10, about half under 6. Minimal adult beverages consumed (by the adults). The deep end looks a bit cloudy so I'm guessing thats not a good sign. I could tell I had phillips screws in the drain this morning.
    1hp pump
    sand filter
    Taylor K-2006
    Aquarite SWG
    P'cola FL
    You might be wise to test now, if it is near 2 or lower, blow a whistle clear the pool and add bleach while you give the kids some Popsicles or something and have them wait a half hour for that to circulate.
    Butterfly's Avatar
    South Carolina
    10,045
    I agree with Anona to clear the pool for half an hour and add some FC!
    With the CYA at 60, the minimum FC is 5 and you started with 6. I'd dose up to about 9 or 10 FC.
    You're done SLAMing when:
    Jun 2010
    Pensacola FL
    40
    everyone's now gone and the results are in
    FC 4
    CC between .1-.5 (barely turned pink)
    pH is still 7.4
    The numbers aren't near as bad as I thought but the pool is still a bit cloudy, not bad but not crystal. Do you think it's just suntan lotion etc and I should dose regularly with chlorine and let the pump run overnight or should I shock it?
    1hp pump
    sand filter
    Taylor K-2006
    Aquarite SWG
    P'cola FL
    No need to shock, but do raise FC a little higher than you normally would to help oxidize any extra sweat, etc, that got into the pool.
    I'd run the pump overnight, since it is cloudy.
    Jun 2010
    Pensacola FL
    40
    thanks, it's already starting to clear up with everyone out
    1hp pump
    sand filter
    Taylor K-2006
    Aquarite SWG
    P'cola FL
