Results 1 to 12 of 12
Thread: fas-dpd test
    alabama
    18
    fas-dpd test
    I've been using this test for a while but since I've started shocking the pool I'm getting odd results with the test. It normally goes completely clear when adding the drops but the last few times I've tried it never gets clear no matter how many drops I put in it. I've also had to add about 2 scoops to get the sample to turn pink but I think I read on here that thats not uncommon. Has anyone ever had this happen? FC should be about 30. CYA is 70. Could water temp affect it or am I doing something wrong?
    11000 gal 12x24 inground. Vinyl with 1hp pump and sand filter.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: fas-dpd test
    How much chlorine have you added recently? From the sounds of it, your FC is really high
    Try using 5ml of pool water and 5ml of bottled water and then count each drop as 1ppm...see if that gets you there
    Feb 2008
    Denton, TX
    5,061
    Re: fas-dpd test
    Not uncommon to have to add two scoops. Are you using the 10 ml sample? 60 drops to clear would equal 30 ppm. Did you stop at 60 drops? It may be higher than you think.
    alabama
    18
    Re: fas-dpd test
    I've been trying to maintain a FC level of 30 for the past 2 days to shock. I have only added a little here and there as it has not lost much. I'm having to guess a little because I can't read the test correctly. Its gets almost clear and just stays there. I used the pool calculator and a large measuring cup to add the bleach so I don't think I overshot it but I could be wrong!
    alabama
    18
    Re: fas-dpd test
    Yes I am using the 10ml sample and I dont remeber where I stopped at like 75 or something but there was no change after about 52 drops. I've done the test for months and have never seen it do this before its usually a definate change to clear.
    Feb 2008
    Denton, TX
    5,061
    Re: fas-dpd test
    My guess is that your FC is so high that although you may be clearing it with the drops, it may be reverting back to a light pink shade so quickly that you cannot notice it. Any sample that has enough drops the clear will go back to pink again if left standing. I think that this may be happening, albeit much faster than usual, because your FC is so high. This is just a theory but I am going to see what others say.
    Guest
    Re: fas-dpd test
    Are you using a SpeedStir or mixing by hand?
    alabama
    18
    Re: fas-dpd test
    I'm mixing by hand. That is a possibility of the sample changing faster than I can tell or at least that would make some sense.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: fas-dpd test
    Why are you shocking? It could be interference from CCs. How long are you waiting in between drops?
    alabama
    18
    Re: fas-dpd test
    Shocking because the water has remained a little cloudy and I saw what appeared to be some algae growing in several spots. When testing I usually stir by hand for about 2 seconds maybe then add another drop and repeat.
    Re: fas-dpd test
    When your FC level is very high, you need to move along a bit more quickly for the first segment of the FC test. As long as the sample remains a solid dark pink you want to be adding drops at the rate of about one per second, or just a little faster. Then you can slow down when the pink starts getting lighter so you don't miss the endpoint.
    Another way to help make the FC/CC test easier at extremely high FC levels is to mix equal parts of pool water and chlorine free water (typically distilled water) together and then test that. When done this way each drop counts as 1.0 ppm of FC or CC. That halves the number of drops you need to use.
    alabama
    18
    Re: fas-dpd test
    Thanks for the help guys. The faster stirring and adding of drops did the trick! Thanks again!
