Results 1 to 11 of 11
Thread: Pool about to overflow from heavy rain
    Marcm15's Avatar
    Jul 2010
    Orange County, NY
    41
    What is the fastest and preferably the easiest way to drain water from my above ground pool? We are in the midst of a heavy rain and my water level is nearing the top of the pool. My skimmer and return face the house (Pool is only about 6 feet away) so I can't open either of those. A quick reply would be appreciated.
    ~21 ft Round
    ~52 inches high
    ~11,500 Gallons
    ~Hayward EC50 DE Filter and a 1hp pump. Flow Rate of 50 GPM
    Feb 2008
    Denton, TX
    5,061
    Re: Pool about to overflow from heavy rain
    You can siphon with a hose or hoses. You can also go to a hardware store and get you a submersible pump to drain some of it off.
    I was just about to post a similar question, but mine is an inground pool. I can drain from the drain port on my filter, so that's not an issue (although my yard will be flooded!!), but my bigger concern is whether or not there is any issue with the pool water overflowing the edge like it is about to. Is there any issue with chemical loss or anything like that due to an overflowing pool?
    20'6" X 38'6" (609 sqft)
    22,500 gal gunite/plaster IGP
    DE filter, Jandy 2HP pump, Nature2 Sanitizer (removed cartridge!)
    Raypak 39.9K BTU gas heater
    2 ColorLogic lights, Maytronics Dolphin pool cleaner
    NCFlyersFan's Avatar
    May 2008
    NE North Carolina
    116
    You should always test your water after a heavy rain regardless of the pool overflowing and make necessary adjustments.
    13,000 gal AGP, Hayward X-Stream 100 sq ft cartridge, 1 HP Hayward Power-Flo Matrix Pump, all on two 6-hour on cycles per day. Baquacil to BBB convert.
    "It is necessary for us to learn from others' mistakes. You will not live long enough to make them all yourself." - Hyman G. Rickover
    dunno of this works, but try this:
    put one end of a hose in the pool, the other in a lower part of the garden.
    Now you need to suck on the hose (the side outside the pool) untill water starts running, normaly, the water will drain. i'm not sure if this is fast enough though.
    Intex pool: Intex® 28' x 12' x 48" Oval Frame Pool with everything that belongs to it.
    i live in Belgiuim, europe
    Aug 2008
    Conway SC
    102
    Quote Originally Posted by Boeie
    OMG, now i know what I was doing wrong all this time.. I been sucking from inside the pool.
    17000 Gallons (16x32) Vinyl In Ground Pool
    Sand Filter
    Install "Finish Date" July 30 2014"
    Propane heater installed.. Used for 1 day.
    City Water.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    for an agp, your best solution would be to siphon using your vacum hose. You be able to siphon much more water this way.
    submerge the entire hose under water with vacum head attached on one end, then close the other end with your hand, pull it over your pool wall and let it drain....just keep an eye on it because it should drain pretty fast
    Feb 2008
    Denton, TX
    5,061
    Quote Originally Posted by dmanb2b
    What dman said!
    todd.scallions's Avatar
    Apr 2010
    Bartlett, TN
    57
    Is it not a good idea to just put the pump on backwash? That's what I have always done when my water level gets up above the skimmer.
    Nevermind. I just noticed this was a question about above ground pools.
    1.) 27,000 gallons
    2.) Sand Filter
    3.) In-ground
    4.) Vinyl Liner
    5.) 1HP/63GPM
    Marcm15's Avatar
    Jul 2010
    Orange County, NY
    41
    I don't know why I am so intimidated by this pool??? The vac hose worked like a charm and was hanging on my wall the whole time I was watching the small amount of water leave the garden hose! You would never know I do all my own home repairs including appliances and yet I am scared to death of the big bucket of water in my backyard...
    Again, Thank you for your responses.
    ~21 ft Round
    ~52 inches high
    ~11,500 Gallons
    bbecky75's Avatar
    Apr 2010
    Jasper, Alabama
    95
    I know this is a little late for a reply but I also own an above ground pool and when I find myself in this situation, I turn the filter to the "waste" setting and let it do all the work. It lowers the lever QUICKLY and waters the grass at the same time....
    30' Above Ground 18,000 gallons, Sand Filter, 1.5 hp Jacuzzi Pump
