Results 1 to 8 of 8
Thread: AA Treatment - Now Cloudy Water
    Wednesday evening I did an ascorbic acid treatment (Stain Free) followed by Metal Away. Thursday night, I vacuumed and then backwashed and increased the SWG. Friday morning the water was very cloudy there was 0 chlorine due to AA. Friday evening I added just a little bleach and muriatic acid because PH was 7.8. (I wanted to keep it down to prevent the staining.) This morning (Saturday) it is still very cloudy. I used my handheld tester until I can get to the pool store for more accurate readings.
    FC 2.0
    ph 7.4
    TA 100
    What should I do about the cloudy water? Is it okay to swim in cloudy water?
    Thanks for the help!!
    Dory
    East TN
    13,000 gal San Juan Fiberglass Pool;SWG; GoldLine Pro Logic Controls
    Hayward Sand Filter; Hayward Max-Flo XL Pump;Polaris 380; Hayward ColorLogic LED
    Raypak Gas Heater
    Re: AA Treatment - Now Cloudy Water
    It is normal for sequestrant to cause some cloudiness for a couple of days after an AA treatment. It is also possible that you are on the verge of getting algae, which will also cause cloudiness, though that seems less likely give that your FC level isn't zero.
    Thank you!! Should I add some clarifier or turn on the super chlorinate?
    East TN
    Raypak Gas Heater
    Not yet. Give it at least two full days to clear up. Also, you don't want to raise the FC level too quickly right after an AA treatment. Bring the FC level up very gradually.
    Thanks!!
    East TN
    Raypak Gas Heater
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    The main issue with swimming in cloudy water that isn't caused from an algae bloom, is the clarity to the bottom... can you see someone in who may be experiencing trouble at the bottom?
    Thanks for the help!! The pool is almost cleared up. My current readings are:
    TC 1.4
    FC 1.3
    Ph 7.4
    TA 89
    CH 174
    I will watch the FC and Ph the next few days and try to keep it low so the stains do not come back.
    Any other advice to keep the stains (iron) from returning to the pool surface?
    Thanks!!
    East TN
    Raypak Gas Heater
    Mar 2007
    San Rafael, CA USA
    12,082
    Just make sure the pH doesn't get too high and be sure to add maintenance doses of metal sequestrant (it not only gets diluted, but chlorine slowly breaks it down as well).
