Thread: Vinyl liner over Concrete or Steel walls
    Jul 2010
    New York
    12
    Hi, I'm a new member on this site. I am in the process of hiring a pool builder for a new vinyl lined in-ground pool in NY.
    A few builders use poured concrete walls. The others use a steel frame , cost is similar. Are there any distinct advantages
    of one system over the other. Thanks in advance for your help.
    20x40 inground 3 1/2'-8', vinyl lined concrete, salt water chlorine generator, DE filter, 2hp pentair pump , Hayward heat pump
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Vinyl liner over Concrete or Steel walls
    welcome neighbor...steel walled pools are pretty popular and can last 40+ years. Depending on where you are in NY Foxx Pools tend to be popular in the Dutchess cty area.
    My advice though...make sure you get some references...I have seen some simple pool builds take all summer
    Jul 2010
    New York
    12
    Thanks for your reply. I'm on Long Island, Suffolk. Concrete wall builders say steel panels bend and walls
    don't sit straight, Steel wall builders say concrete cracks and shifts. I'll keep looking.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    Steel or concrete doesn't really make a difference - as long as the builder is competent!
    If you're on the shore, I'd advise against steel walls, salt water can eat them up However, resin walls would be a viable option.
    Find the builder you trust most and is willing to build the pool you want and let him/ her (I don't want to be accused of being sexist :P ) do their thing with the media they are most comfortable with using! Get a bunch of quotes/ proposals and run them by us, we'll point out issues and help you decide which will best for you
    You done real good by coming here before signing a contract Use this forum as a resource as you are planning your pool.
    Luv& Luk
    -Ted
    Heckpools's Avatar
    Feb 2009
    New Jersey shore
    318
    I love how the pool builders talk trash!!!
    steel is just fine. Im on the nj shore and many of the pools i service are steel walls. I seriously think either would be fine. It really just depends on the builder. ASK FOR REFERANCES!
    [center:3gj9kdnn]Matt Heck
    "HECK OF A POOL SERVICE LLC"
    Serving Ocean co. NJ
    COMPANY INFO BELOW
    http://maps.google.com/maps/place?hl=en ... 2995187987[/center:3gj9kdnn]
    30,413
    I agree that it all depends on a good builder but if everything else was perfectly equal, I would opt for concrete. Done well, it won't crack and provides a stability and longevity that steel may not.
