Results 1 to 12 of 12
Thread: Color of CL test has turned orange
    Jun 2010
    California
    16
    After the pool being out of commission for 2 1/2 weeks, because of pump and a leaky filter, We finally installed a new Pentair pump and filter. Thanks to this board.
    While installing the system, We noticed the water was turning to a greenish, yellow color and also saw algae buildup on the side of the pool. So I decided to add 4, 1lb. bags of shock to the pool. About a day after that, we started running the system and getting it balanced to a PH=8.2, CL=4 and BR=8. I added 1/2 gal of acid to the pool. Next day the levels became CL=2.5, BR=5 and pH=7.5.
    Now it was time to clean the pool. While vacuuming, I noticed very dark spots at bottom of the pool, and I figured it was black algae. I started brushing them but they would not go away.
    I went to the local pool store, with a scraped sample of the black spots. They confirmed that it was black algae. and they suggested to spread this product called Algi-Ban, and after about 2 hours to wire brush the infested area.
    After brushing the black spots, the color of spots turned into a 30% shade of what it was before. It seemed that they were going away.
    Today as I'm doing a CL level test the color of test has turned into an orange color. CL=Orange and pH=7.1
    What did I do wrong? Why Orange?
    36' x 17' rectangular shape, 28K gal in-ground Plaster pool, SMBW 4060, 60ft DE, Whisperflo WFDS-4 1HP and Solar Heat.
    Feb 2008
    Denton, TX
    5,061
    Re: Color of CL test has turned orange
    What sort of chlorine test are you using? Is it a DPD or an OTO test?
    Jun 2010
    California
    16
    I don't know what type of test it is, but I have included a picture of it.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Safety Orange on that tester means somewhere around 18ppm chlorine.
    I bet that algae killer stuff was just powdered shock. Give it a couple days and FC will come down, then you can test pH accurately. Right now FC is so high your pH reading is useless.
    Guest
    I'm not sure how accurate the pH test will be with that big crack through the reservoir
    poolgirl22's Avatar
    Apr 2010
    Stephens City, VA
    595
    details BRUCE....details...sheesh!
    Backyard pool-less, but used to be.....
    16,100 gallon, 18x38 3.5 ft deep oval AG, Vinyl, Sand, 1hp pump
    http://www.poolservicestech.com Liquidator
    http://www.poolcalculator.com/
    http://www.tftestkits.net TFT100 test kit
    Guest
    I hate when I go to check my pH and the test water drips all over my............shoes
    Guest
    Quote Originally Posted by simicrintz
    Thats the beer drooling from your chin...
    poolgirl22's Avatar
    Apr 2010
    Stephens City, VA
    595
    I think we're getting off topic a bit..eh?
    Jun 2010
    California
    16
    That's what I am drinking right now!
    That's not crack. Liquid does not leak through.
    Jun 2010
    California
    16
    And I see the orange color on the yellow/ CL side. The pH is fairly good. I Think.
    Guest
    Quote Originally Posted by kevinm2
