Results 1 to 8 of 8
Thread: cya question
    May 2009
    Trenton NJ
    497
    cya question
    I add water almost every other day because of all this hot weather. I can't get my cya up. I put in the recommended amount wait a week and it either stays the same or drops.
    It does not drop below 50 and I am holding fc steady at 3.5ppm. Is it because of adding so much water?
    20,000 gallon viking fiberglass pool w/aqua comfort heat pump, pentair whisperflo pump 1.5hp autopilot dig-220 swg w/RC42 cell (42,000), pg2000 fiber optic lights
    hayward sand filter(medium is echoglass)
    Blue diamond robot cleaner
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: cya question
    Are you sure you don't have a leak? How much water are you losing? No amount of evaporation would cause a loss of CYA, but a leak sure would....
    May 2009
    Trenton NJ
    497
    Re: cya question
    I do not see any signs of a leak anywhere. The weather has been in the high 90s and a few days of 100 plus degrees. My pool is in direct sun,no shade so we have been getting a lot of evaporation and adding new water.
    I get my cya from ace hardware and it says its 96%. How would you know if you had a leak underground?
    30,431
    Re: cya question
    Does your pool drop more than 1/2" every day?
    May 2009
    Trenton NJ
    497
    Re: cya question
    Yes, durning this heatwave it does.
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Re: cya question
    There is a test for leaking. It's called a 'bucket test', and it's as simple as placing a bucket of water on a step or something so that the top of the bucket is out of the water. Mark the level of the water inside the bucket with a permanent marker. Then mark the level of the pool water on the outside of the bucket. Check back later. If both levels drop the same amount, it's due to evaporation. If the pool drops further, you have a leak.
    Re: cya question
    Quote Originally Posted by Ohm_Boy
    Or a pencil!
    30,431
    Re: cya question
    If your daily loss is like you say, do the bucket test and confirm that you have a leak in your pool.
