Results 1 to 7 of 7
Thread: Cheap pool vacuum
    Cheap pool vacuum
    Hello,
    I purchased a 12'x30" Intex AG pool. I'm doing basic testing (FC and pH). I want to vacuum it but don't want to spend $60 on an Intex pool vacuum because it would cost more than the pool itself.
    There isn't a ton of stuff to vacuum. Can't I just hook up a longer hose the filter/pump and use my pump as a makeshift vacuum?
    12'x30" Intex AG 1,485g pool, w/530gph cartidge filter
    Feb 2008
    Denton, TX
    5,061
    Re: Cheap pool vacuum
    I suppose that you could do that. That idea is about the only thing cheaper than the Intex vac.
    Yep, I'm cheap.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    and resourceful! I hope it works for you.
    Jun 2007
    New Jersey
    653
    I had the 18'x 48" for a while. I did exactly what you describe. However, for fine dust I found the crappy Intex paper filters let it blow right back into the pool. I had to pull the return and vacuum to waste (driveway) to get it clean.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    I have nothing to compare it to, but I really like my AquaBroom. For really fine stuff, line the bag with a knee high nylon. I think it was about $40. I'm on season two with no complaints.
    editing to add: One of the tips I read on this site is great - on your way out of the pool, walk around the edge a few times to create a whirlpool. Five to ten minutes after you get out, all the little junk will have settled into a nice pile in the middle of the bottom of the pool, making vacuuming very quick.
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    thanks for all your help. I ended up getting 10ft of tubing from Lowe's and was going to hook it up to the pump/filter. Then I figured I'd just use it as a siphon and it worked. I put on my dive mask and spent about 15 minutes siphoning-up the debris. Worked great for me. Of course, I lost about 30 gallons of water since I let it pour on the ground. I don't have grass there (only weeds =)) so I really didn't care.
    Sorry to all the conservationists out there!
    But, thanks for the responses!
