Results 1 to 8 of 8
Thread: Any Reliable SWG system to recommend?
    Central Connecticut
    159
    As my search continues for an SWG system, I have read about many issues with just about every system looked at, from faulty control units to output issues. It seems that a lot of people have issues with inaccurate readings on the Hayward systems and others that I have looked at ... Jandy and Circupool don't seem to be popular with the group and therefore, there is little feedback or reviews on these units.
    Does anyone have a unit (model) that has been trouble free, that they can recommend. I am looking for a unit that can handle 35k-40k gallons, since ,y pool is about 26k gallons.
    Thxs
    18x36 IG 26,000 gal, Vinyl Liner, 24" Sand filter Hayward S224T, Jandy AE3000 heatpump and 1.5 HP SuperPump. Circupool RJ45 SWG
    Re: Any Reliable SWG system to recommend?
    I have a Jandy Aquapure system. Mine's been running 5 years with one incident this past year. The cell has performed fine, but I did have to replace an internal circuit board of some sort. Best guess is that I was running the pool with too much salt, which created high amperage in the circuitry ( as explained to me by the pool tech, anyway).
    28000 gallon pool
    DE Filter (60)
    In Ground river rock plaster
    Filter pump = Jandy JHPU 2.0 hp
    None of the manufacturers make a perfect unit. All of them fail in various ways some fraction of the time. One thing to keep in mind is that there are way way more Hayward and Pentair units installed, because those two brands are the ones most builders use. So even though there are many many reports of problems with each of them, they actually have a lower chance of having problems than most of the other brands.
    I installed a Circupool RJ60 this spring. Easy to install and has performed perfectly. Bought online for 1k.
    48,000 gal 'L', vinyl, Triton sand filter, 1 HP Hayward Superpump, 1/2 HP Polaris pump, CircuPool RJ-60 SWG
    benavidescj's Avatar
    Apr 2010
    Fleming Island, FL
    431
    I use the Pentair Intellichlor IC 40 and really like it.
    Carlos
    Pool: 28,000 gallons IG; IC 40 SWG; Pentair 120 gpm cartridge filter; Marble finish; Pentair Wisperflow 1.5 hp; Polaris 360
    Spa: 350 gallon; Bromine
    How to shock your pool
    I use a Circupool RJ45. Easy to install, simple to operate. Works perfect!
    Round AG 17000 gals. Hayward PowerFlo 1 H.P. 60gpm Sand Filter Aqua Smarte Cannister Chlorine Feeder
    Dec 2009
    Central Massachusetts
    2,690
    Quote Originally Posted by benavidescj
    Me too, never had a problem.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Sep 2008
    The Woodlands, Texas, USA
    243
    Goldline PS-8 for last 2 years. No problems. It is FANTASTIC!
    IG 24k plaster with overflow spa. Goldline PS-8 SWG. Tristar 0.75 HP filter pump, Polaris 280, large cartridge filter, 400k BTU NG Max-E-Therm HD, SR Smith Turbo Twister, Life Saver pool fence, ORP managed.
