Thread: dryin out hair
    dryin out hair
    my pool is drying out everyones hair and makiing it very hard to brush. is there anything we can put in the water to make it more hair friendly this is our first pool so we dont know much yet any help would be great
    thanks
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: dryin out hair
    Welcome to TFP.
    Wetting your hair with tapwater before swimming might help.
    Adding salt up to about 1700ppm will probably help as well.
    If you can provide water test results, someone might be able to point out issues that might help as well.
    Feb 2008
    Denton, TX
    5,061
    Re: dryin out hair
    Welcome to TFP!
    Brush and pull that long hair back and put it in a ponytail holder before swimming too.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: dryin out hair
    What are your numbers? (FC, CYA, pH) If you aren't keeping your pH in range that could easily damage your hair. Make sure your water is balanced first and foremost.
    There is another recent thread about this.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
