Thread: Should I be concerned with this?
    Aug 2007
    Northeastern Ohio
    178
    I bought a house with an inground pool last november, and I am a first time pool owner.
    According to public record, the pool was built in 1969. I have no records indicating what, if any, maintenance or repairs have been done to the pool. The perimeter of the pool seems to be pulling away from the concrete surrounding the pool.
    Is there anything I should be looking for as a result of this?
    If it needs to be fixed, how would I go about this?
    There doesn't seem to be any cracks in the pool walls and the gap is pretty consistent around the entire pool perimeter.
    I have another problem that I posted in another topic, so please forgive the duplicate information. I just figured it would be less confusing that way.
    TIA,
    Ron
    ~30000 GAL In-Ground 26'x50' Kidney Shaped Pool
    Hayward EC-75 DE Filter w/1.5HP Hayward SuperPump
    daily user of JasonLion's Poolcalculator
    (12) 2x10 SunGrabber Solar Panels...now if only there was some sun to shine on them!
    ktdave's Avatar
    Katy, TX
    888
    I believe that is just the mastic getting old/shrinking/drying up. Especially since you say it is uniform around the perimeter of the pool. Mastic is a commonly used material that is placed in the crack between the pool and deck.
    11,000 gal. gunite w/midnight blue and white pearl PebbleTec
    Intelliflo 4x160 pump
    Intellichlor IC-20 SWG
    Pentair cartridge filter 420 sq. ft.
    Mastertemp 400K BTU heater
    Legend Platinum cleaner
    Pool School
    JasonLion's Pool Calculator
    TF Test Kits
    30,426
    Yeah, that's a pretty common problem. Pool walls and pool decking are intentionally poured seperately from one another and so they move seperately over time.
    Backer rod and polyurethane caulk are required to do a nice job at that gap. If you're not fimiliar with those, post back for more explanation.
    wardsntx's Avatar
    Jun 2007
    Spring, Texas
    223
    agreed...nothing more than some cosmetic maintenance needed. Good luck.
    Jay
    36' x19' Freeform, 16' waterfall w/ groto and slide, 5' x 10' sundeck, 12" raised spa. Pentair IntelliTouch, Pentair IntelliFlo 4 x 160, Master Temp 400, IntelliChlor Chlorine generator, Aqua Blue PebbleSheen
    Jul 2007
    Suwanee, GA
    528
    Originally, I wanted the look of a concrete deck seamlessly flowing over the beam without any joints. My PB recommend against it because the decking will sink some over time while the pool wall will not and it will result in a nasty crack. Having a joint as you do allows the decking to move around without any damage to the decking. As suggested already, just fill in the cracks with something flexible.
    Gary
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
