Results 1 to 7 of 7
Thread: CYA questions
    Jul 2010
    minneapolis, mn
    31
    CYA questions
    Ok so i have been reading and now know that the CYA takes a long time to disolve, so I have it hanging in a nylon that is attached to a clean empty soda bottle bouy (sp?) style.
    how long will it take to see results, I would like to avoid putting in too much and having to drain and start over so far It has only been 3 days but i have seen little to no difference in CYA levels.
    If it is helpful the water seams to glisten and is clear allthough after swimming it clouds up for a few hours after swimming not sure if that is normal (1st year with a pool)
    We leave the filter on pretty much all the time, and at the current time all i have is the crappy test strips HTH 6way so here is the results I have available.
    TH 200
    FC 5
    PH aprox 6.8 -7.2
    TA 180
    CYA 0+ (not up to 30-50 yet) but slight change in the color on the strip
    temp if it matters is around 70-75 and we have a few back swimmers that have started to "swim" in our pool but not many
    probably TMI but the wholepool thing is new to me and I learn more everyday
    12'x30" Intex AG 1,485g pool, w/530gph cartidge filter
    Feb 2008
    Denton, TX
    5,061
    Re: CYA questions
    Welcome to TFP!
    CYA can take up to a week to dissolve and this is why we don't recommend checking it for a week after introducing it. I haven't seen that method of adding CYA before but I would think that it would work. It might just be a little slower. Many here will put it in a sock and hang the sock in front of a return to add it. Some mix it with water into a slurry and put it in a skimmer.
    Have you checked into getting a good kit. You need to be able to test for FC, CC, pH, TA, CH, and CYA. I would take a look at the Test Kit Comparison page to see the good comprehensive kits out there. Also, since you have an Intex pool, look at the Temporary Pool Guide as it will really help you out.
    benavidescj's Avatar
    Apr 2010
    Fleming Island, FL
    431
    Re: CYA questions
    It can take about a week to get completely dissolved. How much did you put in?
    Carlos
    Pool: 28,000 gallons IG; IC 40 SWG; Pentair 120 gpm cartridge filter; Marble finish; Pentair Wisperflow 1.5 hp; Polaris 360
    Spa: 350 gallon; Bromine
    How to shock your pool
    ajones02's Avatar
    Feb 2010
    Keller, Texas
    118
    Re: CYA questions
    leopardjunkie, FWIW i have a cartidge filter just as you do and tried to add stabilizer in front of the pool returns and it was taking forever to dissolve. i've just started pouring a little bit at a time into the skimmer. for example a 4 lb box of stabilizer took me about an hour or so by adding that way. per the above advice, it does take about a week to register. if you are planning on cleaning your filters anytime soon then i wouldn't add it via the skimmer.
    17,800 gallons, Pentair Clean and Clear 420 Cartridge Filter, Inground, Blue Granite Pebblesheen Interior, Pentair Intelliflo VS-3050 Pool and Spa pump, Pentair Whisperflo 2HP Water Feature pump, Pentair .75 HP Booster Pump for Pentair Legend pool cleaner, Pentair EasyTouch 8-function remote, Pentair IntelliChlor SWG.
    Feb 2008
    Denton, TX
    5,061
    Re: CYA questions
    Good point by ajones02 and I wouldn't recommend adding CYA via the skimmer route with an Intex setup as those little pumps and filters are not designed to handle something like that. The sock method is best for that setup.
    Jul 2010
    minneapolis, mn
    31
    Re: CYA questions
    I have found it is actually disolving quite well maybe that is not good, or maybe the nylon bouy rocks?!?
    So from the responses I am understanding that even after it appears to be disolved it can take aprox a week to register...Or is that it take about a week to disolve and register.
    if it is disolved but still takes a week to register than I probably screwed it up.
    Jul 2010
    minneapolis, mn
    31
    Re: CYA questions
    Quote Originally Posted by benavidescj
    i put in 8oz that disolved from what I can see...no floaties or chunks at the bottom. No results so I put in another 8oz and that disolved... so in a week I will see how much I messed it up?
