Results 1 to 8 of 8
Thread: Peeling Paint?
    Aug 2007
    Northeastern Ohio
    178
    Peeling Paint?
    I bought a house with an inground pool last november, and I am a first time pool owner.
    According to public record, the pool was built in 1969. I have no records indicating what, if any, maintenance or repairs have been done to the pool. The sides and bottom of the pool appear to have peeling paint. A pic of the problem is attached.
    My questions are as follows:
    Is it safe to complete drain the pool and repaint it?
    Do you sand/scrape off loose paint before doing this?
    Is there any brand/type of paint anyone would recommend?
    How can I tell if the pool is plaster, gunite, or concrete?
    I have another problem that I will be posting in another topic, so please forgive the duplicate information. I just figured it would be less confusing that way.
    TIA,
    Ron
    ~30000 GAL In-Ground 26'x50' Kidney Shaped Pool
    Hayward EC-75 DE Filter w/1.5HP Hayward SuperPump
    daily user of JasonLion's Poolcalculator
    (12) 2x10 SunGrabber Solar Panels...now if only there was some sun to shine on them!
    All plaster/gunite/concrete pools are a thin layer of plaster on top of a thick layer of concrete. Gunnite is really just a way of applying concrete using a spray gun. Shotcrete is another way of applying concrete. The plaster layer is what makes it waterproof.
    The safety of draining the pool depends on your local water table. A high water table can cause an empty pool to float right out of the ground. Generally when doing major repairs you drill some relief holes in the pool to allow ground water to get in so it won't float.
    Old paint frequently needs to be sandblasted off.
    Paint isn't the best surface for a pool. It doesn't last all that long and can sometimes allow chemicals from the paint to leach out into the water. If you can possibly afford it I would recommend that you have the pool replastered.
    It kind of depends on your water table, and how long it will take to scrape, clean, and repaint. There are national brands that carry pool paint, but I cannot remember offhand... someone else will be along to answer the rest!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Aug 2007
    Northeastern Ohio
    178
    Thanks for the info. If anyone can recommend someone in the Greater Cleveland/Akron Ohio area to do a replaster, I'll probably go that way. The paint has been a pain, and we get a ton of paint chips in the filter skimmer whenever we brush the pool. Anyone have a rough idea of what a replaster should cost?
    I'm not really sure about the water table around here. We have well water, and haven't had any supply problem despite having a minor drought this summer, so I'm assuming that it is probably at least somewhat high.
    We have a 1.5 foot diameter covered PVC pipe with holes drilled in the sides of it about 2 feet from our pool. I've always wondered what it was for. Is that something to do with the water table? I can post a pic if that would be helpful.
    I really appreciate all the helpful information here. You guys are great.
    Quote Originally Posted by robrinker
    Yes. That should allow you to see how high the water table is also serves a place you could put a pump to try and lower the water table if you need to.
    30,431
    That should be incredibly helpful if you drain your pool. Put a stick in it to see how deep it goes. If it's almost as deep as the bottom of your pool, it will be perfect to insert a submersible pump into and drain the surrounding groundwater from around your pool. That done, you have no worries draining your pool.
    I am in complete agreement with considering a replaster. Paint is always troublesome in pools. Replastering can frequently be cheaper over a period of time.
    Aug 2007
    Northeastern Ohio
    178
    Is it better to get a pool replastered at the beginning of the pool season, or at the end, or does it not really matter?
    It takes about a month for the water chemistry to settle down after a new plaster finish so if you do it in the fall plan on running the pump for another month after that.
    ~Megan
