Thread: Lights out
    Lights out
    I went to turn on my hot tub last night and after a few attempts managed to get it to fire up. I have a Jandy control sytem which doesnt always start the hot tub heater. If I turn off and then turn on at the heater it starts to spark then if I beat on the gas control valve a couple of times eventually it gets going. It seems like it may be a sticky control valve. Is this common?
    Of course nothing happens in isolation. I then noticed the pool and hot tub lights were out. I could not switch any on at the hot tub spalink or in the house at the control panel. Could this be a relay in the Jandy link control box?
    By the way since I started BBB, absolutely no algae, everyone around me has algae problems, way to go BBB.
    In ground Plaster pool 33,000 gal, DE filter, 2.5 HP pump, spa
    TF100 test kit
    Lucas, TX
    Re: Lights out
    I figured it out, the lights are wired through a GFCI receptacle, it had tripped. he heater is still a mistery.
    TF100 test kit
    Lucas, TX
