Thread: Liner at edges of steps leaking
    rdkll's Avatar
    Jul 2007
    Huntsville, AL
    41
    I may have brought this upon myself.......I bought some Borderlines, a product that freshens the top of the liner. I got the 9" high version. I drained the pool about 12-14" and I started at the edge of the steps.......I loosened the top 5 screws so I could tuck the Borderlines under the plastic strip and then retightened the screws. Went all the way around the pool and refilled and it didnt look too bad......
    Now the problem, there is a sucking sound on one side of the steps. I drained the pool and removed the screws to get a better look and it looks like the original liner separated from the backing.....my question, is it as simple as putting silicone back there and retightening. Is there a product that does not have to be perfectly dry.
    Thanks in Advance, I know I will be able to get the answer I need from you guys and girls.
    1) The size of your pool in gallons = 33,500 16x32x40 L
    2) The type filter you have = 300lb Sand
    3) IG
    4) If it's IG, vinyl liner
    5) pump is 1.5hp
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Liner at edges of steps leaking
    http://www.leaktools.com/mm5/merchant.m ... y_Code=EAS
    I would either use the white flex sealer or butyl tape, the tape is more like a sticky gasket material and the flex sealer is similar to silicone but will fully cure underwater and remain flexible.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
