Results 1 to 7 of 7
Thread: New to TFP...trying to figure out my numbers???
    MrsFusion's Avatar
    Jul 2010
    SW Iowa
    80
    Okay, set up my pool the middle of May. I test daily with the test strips that came with the pool/SWG. According to the test strips has been at normal levels until last week. It started reading 0 FC. We have had a LOT of rain lately, pool overflowing. I've had to backwash to lower water level and add salt.
    Been reading tons of posts/threads on here...wow...what a wealth of info!!! Thank you!!!
    I live in a small town, with NO local pool store. All I have is W@lmart. I went and purchased the 6-way test kit. Fairly easly to follow the directions...until I got to the CYA test. I did as instructions say...but, the black dot didn't disappear at all??? I filled the tube to the top...no black dot disappearing. I know you guys will probably tell me to order the kit offered here...but, it's not an option right now. Not sure what I did wrong? And the test kit only has enough for two CYA tests...so I'm gonna wait awhile before I test for the CYA again.
    I tested my pool this morning here are results-
    FC- 0
    ph- 7.8
    TA- 110
    (this was before I bought the 6-way kit)
    So I used the pool calculator to figure how much bleach I needed to add. I added bleach and waited an hour(ran the filter for the hour). New test results-
    FC-5
    ph- 7.8
    TA- 100
    CH- 110
    CYA- 0 (I might have done it wrong???)but, I followed the directions....
    My pool water is very clear and no algae that I can see. My filter is on a timer for 9 hrs/night. SWG runs 6 hrs/night. I have a family reunion party at my house in 3 wks. I'm wanting to make sure that my pool water is clean/safe for everyone
    Any advice will be greatly appreciated!
    5,000 Gallon 16'x 48" Intex Ultra Frame, Waterway 1hp sand filter, Intex SWG, AquaCritter, TF100
    Climate/Location: SW Iowa
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: New to TFP...trying to figure out my numbers???
    If you have only been chlorinating via SWG (no trichlor pucks or dichlor shock), and never added CYA (aka stabilizer) than your CYA is indeed 0.
    You need to add enough to get up to 70 - 80ppm. You can use the pool calculator to determine how much you need.
    Some Walmarts carry CYA in the pool aisle. If yours doesn't, you can get it online. I just bought some off eBay with a decent price and free shipping.
    Without CYA, your FC is quickly burned off by the sun and the SWG can't keep up.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    You can supplement your FC with bleach until you get some CYA in the pool. Once you get the CYA in, assume you have that the level you are targeting and add bleach to reach your recommended FC level until the SWG catches up.
    Love TFP? Become a
    TFP Supporter!
    MrsFusion's Avatar
    Jul 2010
    SW Iowa
    80
    Thank you. Off to get some CYA!
    MrsFusion's Avatar
    Jul 2010
    SW Iowa
    80
    Well, I put the CYA in on the 12th. I haven't re tested it with the drop kit yet, but, the 6-way strip is still saying 0. But, my Cl is off the chart on my test 5+. Here are my results from today.
    FC 5+
    pH- 7.5
    TA 110
    CH 230
    CYA 0
    Salt 2490
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    The strips are worthless when it comes to CYA.
    How much did you add and how did you add it?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    CYA can take a week or more to show on test, wait a few more days before using the last of your CYA test reagent
    Ike
    p.s. If something does go wrong on your next CYA test, TFtestkits does sell a single item CYA only test for $17+shipping
