Thread: high phosphate levels
    wanted to know if high phosphate level could be the cause of a fc reading of 0. have taylor k-- shows tc reading and all other #'s seem to be up to par. have been shocking but still no fc reading. water is crystal clear. 25,000 fiberglass with a cart. filter. Any suggestions?
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: high phosphate levels
    Phosphate does not consume FC...algae does.
    How are you shocking? What is your target shock FC? What are your numbers, including CYA? How are you chlorinating?
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    22,550
    Phosphates won't cause your FC to go to zero. If you keep your FC level high enough for your CYA level (see chlorine/CYA chart) you can ignore phosphates.
    What have you been shocking with?
    You need to read Pool School on how to shock. You also should order a good test kit if you don't already have one. It will allow you to take control of your pool and things will go much better once you know the real numbers.
