Results 1 to 13 of 13
Thread: What to use as a base for filter/pump/chlorinator?
    JerseyKRS's Avatar
    Jun 2010
    near Tampa, FL
    12
    Hi everyone. I've been lurking the boards for some months now. The information everyone shares is so helpful! I'll be putting up a thread once I have everything up and running.
    I'm getting ready to fill the pool, but I want to know what everyone recommends for a base for my filter. I was planning on leveling a rectangle on the ground and using large garden tiles, but still have nagging thoughts of a better solution. Pouring a small slab is not an option I want to consider.
    This is my filter:
    This is the smaller chlorinator:
    Any help is appreciated, thanks in advance!
    Intex Easy Set 18' x 48" AGP - 5,500 gals.
    Intex 2,100 gph Zeobrite filter w/.95 hp pump
    Intex Krystal Clear Saltwater System (w/copper ionizer)
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Re: What to use as a base for filter/pump/chlorinator?
    Find the patio block that appeals to you at your local hardware store uses as many as you need to make a base for your equipment. Be sure to remove the grass and level the area under the blocks first and everything should be fine!
    Love TFP? Become a
    TFP Supporter!
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    I concur. Good idea
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    You can also use a small PVC AC condenser pad sold at your local plumbing/HVAC supply store as another option
    22,553
    Using Pavers is a good option if you don't want to pour a slab. I used bricks under mine.
    Also you should remove the test results from your sig. Since they change regularly and. when we're replying to your post we don't see your sig, it makes it better to put those in the post as needed. Not to mention that you're not supposed to have but 5 lines in your sig.
    [edit] Wow, three people beat me typing. [end edit]
    I like the A/C pad idea too.
    JerseyKRS's Avatar
    Jun 2010
    near Tampa, FL
    12
    Quote Originally Posted by zea3
    Quote Originally Posted by Melt In The Sun
    I concur. Good idea
    That's what I figured was the best option.
    Quote Originally Posted by dmanb2b
    I thought about this also, but I'm worried the weight of the filter with the 55 lbs. of Zeobrite and water will be too much load and crack the plastic. I'm going to look into this more...
    JerseyKRS's Avatar
    Jun 2010
    near Tampa, FL
    12
    right on I'll remember to post them when I need to.
    Oct 2009
    3,899
    It won't be too much weight. Our heat pump is on one, and it weighs about ten billion pounds.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Mine is on an AC pad----------22" 250 lb. filter and pump. Looks nice too!
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Quote Originally Posted by woodyp
    Yup...I have the same set-up 250lb sand filter with pump...I'm pretty sure condensers are pretty heavy to begin with, which gave me the idea...here is a pic for reference
    http://s702.photobucket.com/albums/ww30 ... g&newest=1
    JerseyKRS's Avatar
    Jun 2010
    near Tampa, FL
    12
    thanks a lot guys, I just ordered this:
    http://www.pexsupply.com/DiversiTech...ck-Pad-36-x-48
    jsf0656's Avatar
    Apr 2010
    south georgia
    313
    Quote Originally Posted by JerseyKRS
    jerseyKRS, how is the zeobrite working for you?
    18x52'' intex AGP, 6981 gal, 2650 intex sand filter,
    thru wall skimmer, SWG, 52'' 20G overlap liner, intex pool light
    JerseyKRS's Avatar
    Jun 2010
    near Tampa, FL
    12
    Quote Originally Posted by jsf0656
    well, considering the pump isn't up and running yet, it's working out very well sitting in my TV room. lol
