OK, the temps have been in the high 80's-low 90's, humid, sunny. Had a higher than normal bather load over the holiday weekend but normal since then (with the possibility a little kid peed in it). Before, I was losing 0 to maybe 1ppm chlorine. Now I am losing about 1-2 during the day (I add more chlorine) and 2ppm overnight. Is it the weather, the possibility a kid peed in the pool over the weekend or what?
As of this am:
Cl 3 (I usually target 5-6)
pH 7.5
TA 120 (still in the process of bringing it down)
CYA 40
Clarity: Clear but not as sparkly as when the weather was cooler
Pool temp: VERY warm, almost lukewarm
I am using the HtH 6 way kit this year. (next year I will use the TF100)
As of this am:
pH 7.5
CYA 40
