Results 1 to 11 of 11
Thread: Cause of chlorine loss
    Dayton, Ohio
    79
    OK, the temps have been in the high 80's-low 90's, humid, sunny. Had a higher than normal bather load over the holiday weekend but normal since then (with the possibility a little kid peed in it). Before, I was losing 0 to maybe 1ppm chlorine. Now I am losing about 1-2 during the day (I add more chlorine) and 2ppm overnight. Is it the weather, the possibility a kid peed in the pool over the weekend or what?
    As of this am:
    Cl 3 (I usually target 5-6)
    pH 7.5
    TA 120 (still in the process of bringing it down)
    CYA 40
    Clarity: Clear but not as sparkly as when the weather was cooler
    Pool temp: VERY warm, almost lukewarm
    I am using the HtH 6 way kit this year. (next year I will use the TF100)
    AG Intex Ultra Frame
    Round 16 ft x 48 in, 5061 gal
    2500 gph Intex Krystal Clear Cartridge Filter
    BBB
    30,413
    Re: Cause of chlorine loss
    If you think you are losing 2ppm overnight, you need to perform an overnight FC loss test to confirm that.
    If you are losing more than .5ppm at night, you have organics in the pool and need to shock. Directions for the overnight FC loss test and How to Shock your Pool are both up in Pool School.
    My advice is to get out in front of this quickly by shocking to completion (less than 1 FC loss overnight; less than .5 CC; AND clear sparkly water). Even if you can't test for CC, you can apparently do the overnight loss test and tell feel (non-slippery/slick vinyl) and look of the water. Then you could target an FC or so higher for a time as insurance. Especially with an Intex, it is important to prevent algae from getting any foothold since clearing it is so difficult with the ltitle filters.
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    Dayton, Ohio
    79
    Yeah, I figured I would just go ahead and shock it before I go away and leave it in my husband's hands (scarey). Went to the pool store for the first time just to see what readings I would get compared to mine.
    Everything was the same as my reading except for the CYA. Mine is 40 and they got 60. Makes a difference if I am going to shock. What do you think? They used strips that went into this scanner-like thingy. Go with the higher CYA or the lower?
    BBB
    30,413
    Always trust your own results. If you are comfortable with the testing procedure you used and the test itself, go with your number. If not split the difference and go with 50ppm.....that'll work just fine.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Your test is more accurate, but it won't hurt to go with the higher level.
    Love TFP? Become a
    TFP Supporter!
    Can high phosphates can fc level to be 0? Unfortunately can not get a fc reading on my taylor k. Have a tc reading. 25,000 fiberglass. All other level are o.k. Was told high levels of phosphates are "eating" up the chol. Seems strange to me. Any opinions?
    Dayton, Ohio
    79
    Thanks Everybody!
    BBB
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Robinixie,
    Phosphates don't do that; it's just a line to hopefully sell you some overpriced, unnecessary phosphate remover. If your kit is showing TC but no FC, all your chlorine is present as CC and you should definitely shock that pool!
    If you start your own thread, more people will see it and offer their help.
    Thanks melt...it seemed a little far fetched. How will I figure how much shock? In the meantime I will figure out how to start a thread.
    To start a new thread, go to board index. Then click on the subforum that your question pertains to. Once you do that you'll see a blue box that says "new topic." Click that. Type in your subject and your question.
