Thread: How to Empty a Pool with Explosives
    Sep 2009
    TN
    49
    Guy wants to empty is above ground pool. Decides to use an M80...
    http://www.break.com/index/rednecks-...-with-m80.html
    new in 2009 - 18' x 36' IG vinyl liner, 23,300 gallons
    24" sand filter w/ 1.5hp pump
    Polaris 280 cleaner w/ booster pump
    ivyleager's Avatar
    Sep 2007
    Raleigh-Durham,NC
    489
    Re: How to Empty a Pool with Explosives
    Pool looks green by the end of the video. Maybe he should have done a bit of internet searching and found us.
    CaryB
    36 x 18 IG vinyl, 25K, 1 HP pump, sand filter
    1 skimmer, 2 returns, no main drain
    Old school: PoolSolutions test kit
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Obviously not a TFP alumn
    I've seen a lot of these videos on U-Tube and I still can't understand why people would do that. . .
    17.5K IG Pool with Spa spillover and fountain, Plaster Finish, Purex Triton CC420 Cartridge Filter, Pentair Intelliflo XF VS motor, Laars LX GasHeater, Polaris 360
    dorpo75's Avatar
    Jul 2009
    NE Ohio
    256
    There had to have been alcohol involved in that decision making process. Those guys must have money to burn.
    2005 Dimension One Venture model 370 gal. hot tub. We'll be using the TFP method to keep it clean and ready to use!
    TFP - The Finest Phorum on the Net!
    guamguy's Avatar
    Feb 2010
    Guam, USA
    388
    I think they probably could have had more fun USING that pool after they cleaned it up rather than the 15 seconds of fun they had blowing it up...
    12,800 gallon IG plaster kidney-shaped pool, waterslide, 800 gallon spa.
    1HP 2 speed Sta-Rite pool pump, 1.5 HP Sta-Rite spa jet pump. 2 skimmers, 1 main drain
    Purex-Triton TR-60 325 lb.sand filter. 2" Plumbing, Intex SWCG, TF-100 test kit.
    Link to pics of my pool! http://www.troublefreepool.com/my-oasis-t26558.html
