Thread: Yikes! Houston, we have a problem
    poollizard's Avatar
    Jul 2010
    Apple Valley, California
    26
    Well, like I said, I'm just getting started with pool chemistry. Here's the results of my first test:
    I only did four tests, and I don't have a FC test in my kit:
    Cl = Orange (Off the scale)
    pH = 7.6
    TA = 170
    CYA = >100 (Off the scale)
    So, from what I've been reading, I probably need to drain and refill about 50% of the water, right? If that's the case, it'll have to wait until Saturday, as I don't have enough time in the evenings to do much more than water tests. Is there anything I can do in just a couple of hours in the evenings?
    I probably should add that right now, I have full sunlight all day, every day, with the outside peak temps ranging between 90 to 100. Not sure what the water temp is, I don't have a water thermometer. Gotta get one.
    Where should I begin?
    Thanks!
    21,500 Gal IG plaster, free form, PAC-FAB NAUTILUS NFS-60 DE filter; Pentair Intelliflo VF pump; TELEDYNE LAARS Series One gas heater. Hayward PoolVac V-Flex pool cleaner. Taylor K-2006 test kit.
    Feb 2008
    Denton, TX
    5,061
    Re: Yikes! Houston, we have a problem
    I would first go ahead and do that 50% drain to get your CYA down and then go from there.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,056
    I don't know where you are in California, but a lot of us are under water restrictions. My pool is sparkly despite CYA around 160. It can be done. It just means the color-matching test is out for chlorine. Soon as I get caught up on a few things, I may get R/O done. Or drain and refill if/when they lift restrictions. How does your pool look? Is it clean and clear?
    poollizard's Avatar
    Jul 2010
    26
    Thanks for your input, Richard.
    Yes, the pool water is clean and clear. And, as far as I know, I don't have any water restrictions. I'm in the 92307 zip code. There's a lot of pools in my area, but I've never heard of any water restrictions for refilling a pool, but I've never asked either. Good point, maybe I should find out.
