Thread: New pool owner - question
    Hi,
    We just set up our first pool, its a 16x3'6 intex inflatable pool with a krystal clear filter. Our only water source is our pond, we have a huge system set up in our basement completed w/ a chlorinator and two huge water tanks and 3 wall filters. I'm sure there's more but unless you need complete details I don't know off hand, that's not my department
    It took us a while to get it filled up but now it is all said and done, and the water is not pretty looking.. Its a yellowish color and I'm not liking it.
    The book that comes w/ the pool isn't good for details on what exactly needs to be done. I have bought some test strips and shock and chlorine sanitizing tablets. I added 1lb of the shock to the pool and added (5) 1" chlorine tablets by HTH.
    I just finished doing a test strip and got the following readings
    FC: 3/6
    PH: 7.5 - 7.8 (kinda right in the middle, too hard to distinguish which one)
    TA: 40
    TH: 200
    CYA: 30-50
    I'm not exactly sure what all I can do or what I can add that won't throw the readings off too much to turn the water clear or at least a little more clear. I'm new to this and don't understand what exactly all the chemicals do and when its safe enough to be swim ready.
    TIA!
    ~Auty
    16x3'6 Intex Inflatable Pool
    Krystal Clear filter
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: New pool owner - question
    Welcome to TFP.
    Your water is reasonable. The primary issue with safety is chlorine. The important thing is that the chlorine is always above the minimum levels in the Chlorine CYA Chart
    You'll want to read Pool School, and particularly Temporary Pool Guide
    and ABC's of Pool Water Chemistry
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Before you get much further along, also note that the HTH chlorine tablets usually contain copper. You don't want that in your water!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,974
    The test strips are only marginally better than taste-testing your water. Get a good test kit. They're compared in Pool School, where you ought to do some reading. If the pool is going to stay up all year, be careful with the tablets - they'll raise CYA to astronomical levels. If it'll get drained at the end of summer, who cares?
